Author Topic: windscreen washer fluid  (Read 2409 times)
Offline glenn_g60
  • Red Ed30 No. 884
« on: May 20, 2012, 08:15:31 pm »
Was topping up the water for the windscreen yesterday and added in some halfords stuff i had in the garage. Bit random but what do other people use? Is there anything special anyone uses or just any old stuff and some water? Not something that normally gets talked about compared to oil, fuel, etc. Thoughts and ideals.
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: windscreen washer fluid
« Reply #1 on: May 20, 2012, 08:17:08 pm »
i know on the 8P using non-VAG stuff gums up the rear wiper's mechanism so on that basis i wouldn't use anything else. it's topped up for free during a service anyway, so if you're servicing it regularly enough it should hardly ever need topping up.
PLANS: Stage 2+
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #2 on: May 20, 2012, 08:18:48 pm »
I tend to buy the pre mixed stuff from Halfords in 5ltr containers and in the 5+ years i have been using it haven't had any issues.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #3 on: May 20, 2012, 09:03:27 pm »
I only use the VW stuff.
I know someone who uses Fairy liquid.  :booty:
'07 Red manual
Offline Johnny_tro
« Reply #4 on: May 20, 2012, 09:26:12 pm »
I also use VW stuff, but looking for something more cost effective. I have headlamp washers and its a joke the amount of time I have to keep topping up!!
I need one of these on a tow bar.....
Offline George
« Reply #5 on: May 20, 2012, 09:58:57 pm »
Pull the fuse out then!  :P
I use the VAG stuff, miles better than anything else I've tried. Autoglym make some too!
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: May 20, 2012, 10:10:03 pm »
Vhe vw stuff also have a nice smell to it...  :happy2:
Silver is the way !
Offline Stg123
« Reply #7 on: May 20, 2012, 10:12:37 pm »
I use autoglym screen wash in mine- seems to work well and hasn't blocked the jets up or caused any problems
Offline Russ_leeds
« Reply #8 on: May 21, 2012, 07:50:39 am »
autoglym for me aswell. IIRC its to do with the freezing points of the fluid that causes problems for the jets
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline holland15h
« Reply #9 on: May 21, 2012, 08:18:18 am »
I use Volvo stuff, seams to work fine for me with no problems
Offline nezquick
« Reply #10 on: May 21, 2012, 09:23:27 am »
AutoG for mee  :happy2: but I always have spare halfords mix in the back and used halford on my previous car and my brothers car and have never experience a problem.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #11 on: May 21, 2012, 09:32:18 am »
Genuine VW in mine,it's not expensive. :happy2:
Offline richtung
  • -Receive: 56
« Reply #12 on: May 21, 2012, 11:21:12 am »
Me too... the VAG stuff is specifically designed for the fan jets that we have - helps prevent blockages.
When mixing for the summer, the concentrate goes a long way.
I got a box of 10 off ebay and it worked out at under £3 per bottle (i think), perhaps that could be an option?
Hope this helps
Rich
Offline gulfstream11
« Reply #13 on: May 21, 2012, 12:33:15 pm »
I don't do it but do you dilute the VW stuff..You know empty the bottle in and add water??
Offline richtung
  • -Receive: 56
« Reply #14 on: May 21, 2012, 12:54:26 pm »
yes, you dilute it.. you would only use it neat in extreme cold temperatures, -30c or colder i think.
For normal UK conditions (above freezing), i think the dilution ration is 1:4 but stand to be corrected..
Rich
