Author Topic: knocking when turning right  (Read 11207 times)
Offline Russ_leeds
« on: May 21, 2012, 11:59:07 pm »
My car has suddenly developed a knocking noise mainly when turning right and/or a bumpy surface. It sounds quite bad so i've just limped it home :chicken: My mods are in my sig if thats any help  :drinking:
Not what I need really a month before I drive across half of europe :fighting:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline markevo6
Re: knocking when turning right
« Reply #1 on: May 22, 2012, 08:55:55 am »
Sounds exactly the same as mine , it turned out to be a split cv gaitor and the grease had dried out .
I used an independant , the new joint was about £ 50 I think plus the labour to swap it over .
I was initially thinking steering rack , thankfully it wasnt .
Good luck
Mark
Offline Russ_leeds
« Reply #2 on: May 22, 2012, 09:26:32 am »
cheers. I've just been out and started the car and I noticed a rattling noise coming from underneath the front end, also it makes the knocking noise when turning the wheel when stationary?? :confused:
« Reply #3 on: May 22, 2012, 09:36:48 am »
Hope you don't have to cancel the trip mate
Offline Russ_leeds
« Reply #4 on: May 22, 2012, 10:08:27 am »
cheers mate, me too. Hopefully it won't be too expensive. I'm taking it so a vw indie this afternoon  :sad1: :fighting:
Offline Russ_leeds
« Reply #5 on: May 22, 2012, 11:02:09 am »
Ok so I just took the car for a quick spin round the block and it seems to do it when going over a bumpy road more than when turning, it almost sounds as if its under my feet/centre console.
Any one got any ideas please?
« Reply #6 on: May 22, 2012, 11:18:41 am »
I've got a quiet knocking too.  Got subframe bolts to see if it helps.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #7 on: May 22, 2012, 11:35:11 am »
Sounds a lot like the problem with mine. I tried drop links but they made no difference  :sad1:
Could be your strut top mount?
« Reply #8 on: May 22, 2012, 11:45:22 am »
New top mounts made bugger all difference  :sad1:
Offline Russ_leeds
« Reply #9 on: May 22, 2012, 02:04:59 pm »
Found the problem, my anti roll bar d-clamp has snapped causing the arb to knock
Offline reflex11
« Reply #10 on: May 22, 2012, 03:43:40 pm »
i think i had this, when i went full lock i had it, mot failed cv joint replaced it hvn't heard anything since  :drinking:
Offline Russ_leeds
« Reply #11 on: May 22, 2012, 04:15:46 pm »
Cheers, my cv joints are fine, its the clamp from around the driver side of the front arb that has snapped, causing the d-bush to move round so the arb is knocking (metal on metal) on the frame.
I'm just glad its not anything major. I've pm'd w8 performance who supplied them and waiting for his reply.
Has anyone else had this? Mike, Simon seemed to think you'd had this at some point?
« Reply #12 on: May 22, 2012, 04:55:32 pm »
My front Arb clamp a day after being back on uk roads  :fighting:
Offline Russ_leeds
« Reply #13 on: May 22, 2012, 04:59:13 pm »
Cheers mate, looks pretty much the same thing, except mine has snapped a bit further up. What arb do you have and what causes this? My arb only got fitted about 4 months ago and I always try and avoid potholes and I pretty much CRAWL over speed bumps
« Reply #14 on: May 22, 2012, 05:05:10 pm »
Neuspeed 25mm Arbs mate
Poorly lit road, caught a speed bump at 25mph in dover. Knock knock knocked my way to Sy's
