Author Topic: Dipping Side Mirrors  (Read 3345 times)
Offline Johnny_tro
« on: May 22, 2012, 11:20:22 pm »
I have electric folding, heated side mirros with puddle lights. When on VCDS I can confirm the box saying 'reverse dipped' (or something like that) was active, however when I go into reverse my mirror(s) do not dip.
Does anyone one the process of 'how to set thesr up' ?
Offline Golfster S
Re: Dipping Side Mirrors
« Reply #1 on: May 23, 2012, 05:49:03 am »
Can't help with the set up, but the passenger side only dips when the Electric Mirror adjustment switch is set to "L"..
Rich... :smiley:
Reflex Silver GTI Edition 30
« Reply #2 on: May 23, 2012, 08:28:19 am »
What year is your car?
Offline Johnny_tro
« Reply #3 on: May 23, 2012, 09:31:15 pm »
Its a 2004
Have tried reversing with the swtich in L, R, heated - all options.
I believe the process is something like.........dip the left mirror, while in the put the car is reverse, then flick to switch to R then out of reverse. < this sort of thing. Option is OK on VCDS, no faults etc - but does not dip when reversing....?
« Reply #4 on: May 23, 2012, 09:48:51 pm »
It's only cars post 2007 did dipping mirrors appeared. You can't enable it in vcds with these early cars.
Offline Johnny_tro
« Reply #5 on: May 23, 2012, 09:55:03 pm »
I have standard factory fitted.......
Folding
Heated
Electric
Puddle lit lights
On VCDS its showing active?
Offline Luka
« Reply #6 on: May 23, 2012, 10:10:49 pm »
I think mine is ticked too but without the proper door controllers, etc. it won't work.
Sold - 2006 Tornado Red GTI 3dr
Offline Johnny_tro
« Reply #7 on: May 23, 2012, 10:13:39 pm »
Door controller also working and all good.......
From what I can understand they need setting- esp is you have pulled the battery or something
« Reply #8 on: May 23, 2012, 11:35:16 pm »
Maybe Darren can help you out  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #9 on: May 24, 2012, 12:08:12 am »
Switch on ignition but do not start the car
Put mirror selector switch to L
Select reverse
Position the mirror how you want it
Take car out of reverse
Turn off ignition
The mirror should then move back to its original position and from then on it will work. However I'm pretty certain this only works if you have electric memory drivers seat.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: May 24, 2012, 06:09:17 am »
You won't have it on 2004 car
Only way to get it is to have a memory motor in passenger side mirror and a GEN3 Max controller
This is what I added to my car
Cluster and Key coding
Location Great Yarmouth
