Author Topic: Oil on spark plugs, white smoke from exhaust possible causes  (Read 7188 times)
Offline Sammy
Firstly i thought it was down to the pistons or rings but had a compression test done today and all cylinders read the same amount of pressure so this must mean nothing from the engine side?
I am trying to pinpoint the issue here and wondering what other tests can be done to find results, What do the symptoms look like?
yesterday i changed 4 sparkplugs and after a while cylinder 2 started misfiring, got the sparg plug out to find it was gone so changed that plug and now same thing has happened again misfire from the same cylinder any ideas?
Also if you dont want to help dont bother tellng me to go to a VAG specialist because I have, The place am at has a mechanic from the dealer and they are german car specialists, I have excellent service from them for the last 4 years and this is where all the work will take place end of.
GTI MK5 with all the gooodies
K04 power going on soon!
Offline micky 32
Re: Oil on spark plugs, white smoke from exhaust possible causes
« Reply #1 on: May 22, 2012, 11:41:48 pm »
The turbo could be at fault.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
Offline Russ_leeds
« Reply #2 on: May 22, 2012, 11:45:07 pm »
How many threads?
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
« Reply #3 on: May 22, 2012, 11:46:45 pm »
How many threads?
For something that he and his speshulist know best about.
Offline Sammy
« Reply #4 on: May 22, 2012, 11:54:28 pm »
Ok thanks Ian Beale
Offline Sammy
« Reply #5 on: May 23, 2012, 12:03:18 am »
It may be so but if the turbo was faulty why would excess oil go on to the spark plugs, initially the smoke made me think it was the turbo
Offline edd666999
  • -Receive: 89
« Reply #6 on: May 23, 2012, 12:09:25 am »
How many threads have you got going  :grin:
Try and keep it all in one place as its getting difficult to follow and therefore difficult to help!
Offline Sammy
« Reply #7 on: May 23, 2012, 12:14:10 am »
No I actually think the other thread had loads of mixed results, where as today after compression test it's starting from a different level as it seems I don't need to strip the engine no more, and better to start fresh
« Reply #8 on: May 23, 2012, 12:27:02 am »
but won't this thread get mixed reviews :grin:
Offline Sammy
« Reply #9 on: May 23, 2012, 12:32:16 am »
No it won't because like I said its a new problem today duh, only if people decide do then it will which I dnt give a crap about am here to get help not be spammed
« Reply #10 on: May 23, 2012, 12:38:14 am »
its all the same problem--we are trying to help
Offline DonalM
« Reply #11 on: May 23, 2012, 01:00:20 am »
I am helping when I tell you this....
Please bring it to someone who has plenty of experience with these engines. If you had first then you might'nt be in this mess.
http://www.mk5golfgti.co.uk/forum/index.php/topic,31784.0.html
TR DSG Gti- K04, TTRS Brakes, BBS, H&R, RNS, Xenons, Leather, Ed30 Front lip, US Smooth Grill, RVC, Miltek, WALK, Loads of Forge bits + lots more.
Offline Sammy
« Reply #12 on: May 23, 2012, 01:07:30 am »
I very highly appreciate members that are genuinely trying to help me, giving me rubbish just makes threads boring and long nd helps no1,
Best to keep it nice an simple so people can get help when they need it,
Keep it coming guys and thanks!  :smiley:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=b6728ce4hmm86t9p479u3u9ptg&/topic,19740.0.html
« Reply #13 on: May 23, 2012, 01:08:37 am »
And they dont know whats wrong with it? So your quite happy to let them try and fix this issue knowing they dont know their arse from their elbow?  :popcornsoda:
Offline Sammy
« Reply #14 on: May 23, 2012, 01:12:59 am »
Yes its called diagnosing? You would know wouldnt you what on earth you can't  just know the problem out of your head you need to do testing don't you??
Please stay on topic and stop banging on about the garage
« Last Edit: May 23, 2012, 01:15:05 am by Sammy »
