Author Topic: 5w40 or 5w30?  (Read 57900 times)
Offline chopper
5w40 or 5w30?
« on: May 23, 2012, 08:23:54 pm »
running 350bhp ed30 and oil levels are running low, and i normally top up with 5w30. opieoils recommended 5w40 instead. anyone else shed some light on which is best?
Offline B1NCC 1.8T
Re: 5w40 or 5w30?
« Reply #1 on: May 23, 2012, 08:27:44 pm »
5w30 is what VW recommend mate.
20vt mk2 & GTI Edition30 no 0540
Offline Luka
Re: 5w40 or 5w30?
« Reply #2 on: May 23, 2012, 08:38:37 pm »
I believe greater power MK5s should run a more viscous oil to cope better with hotter engine temperatures?
AFAIK.
Sold - 2006 Tornado Red GTI 3dr
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
Re: 5w40 or 5w30?
« Reply #3 on: May 23, 2012, 10:07:34 pm »
5w 30 and Castrol edge only in my view
Paul
  • -Receive: 291
Re: 5w40 or 5w30?
« Reply #4 on: May 23, 2012, 10:11:25 pm »
5W-30 in a standard engine. Most on here who are modded also use 5W-30 but there's a growing consensus that 5W-40 is better for a modded engine as it tends to run hotter.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: 5w40 or 5w30?
« Reply #5 on: May 23, 2012, 10:24:52 pm »
I echo above... but run 5w-30 still... :laugh:
Diesel Daily Hack.
Offline chopper
Re: 5w40 or 5w30?
« Reply #6 on: May 23, 2012, 11:47:39 pm »
ill probably run 5w30 this time, but 5w40 shouldnt cause any issues if i run it next time?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=dbgehv2ncaeickan77h7hstrgj&/topic,19740.0.html
Re: 5w40 or 5w30?
« Reply #7 on: May 24, 2012, 12:04:24 am »
5w40. The oil will keep its viscosity at high temps better :-)
Offline gazon69
Re: 5w40 or 5w30?
« Reply #8 on: May 24, 2012, 07:44:58 am »
All the way. Did mine last week with castrol edge. They had an offer on at halfrauds :happy2:
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: 5w40 or 5w30?
« Reply #9 on: May 24, 2012, 08:45:03 am »
Personally I'd use a better oil than Castrol. Mobil would be my choice.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline gazon69
Re: 5w40 or 5w30?
« Reply #10 on: May 24, 2012, 09:06:39 am »
Not really that bothered tbh as i change it every 4k anyways. :happy2:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: 5w40 or 5w30?
« Reply #11 on: May 24, 2012, 09:09:24 am »
Here in the states the recommended grade is 5W40. Going to do a change this weekend with Castrol SPT synt. and installing a drain valve as well. Drains will just be a flip of a switch from now on.
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
Re: 5w40 or 5w30?
« Reply #12 on: May 24, 2012, 09:24:28 am »
Castrol Edge 5w30 is far superior for TFSI engine then any Mobil oil. In fact don't think any Mobil is approved for VW TFSI engines
Re: 5w40 or 5w30?
« Reply #13 on: May 24, 2012, 09:28:01 am »
Drain valve?  :popcornsoda:
Offline james
Re: 5w40 or 5w30?
« Reply #14 on: May 24, 2012, 09:39:04 am »
it is the oil slick button next to EPS.  :happy2:
