Author Topic: Next time you check your tyre pressure....  (Read 4107 times)
Offline tony_danza
  • -Receive: 112
Re: Next time you check your tyre pressure....
« Reply #15 on: May 27, 2012, 09:45:28 pm »
Huh? I checked in my boot and all I found was a battery. I kicked it a few times, seemed hard enough so I'm assuming it's the correct PSI.
I've had that sickening punch in the gut of lowering a jack only to see the tyre squish to nothing. Luckily I had a tyre inflator.
Sideways yo!
Offline Frenzy
  • -Receive: 29
« Reply #16 on: May 27, 2012, 09:56:08 pm »
no you need to lick it to test it otherwise it may be flat...
er i'll get my coat now  :sad1:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=2u21c8mp14rs4cp3sqk7n2s0t6&/topic,19740.0.html
« Reply #17 on: May 27, 2012, 11:25:25 pm »
Sounds like the battery is ok then....  :P
