Author Topic: Soundpack Amp power  (Read 794 times)
Offline johnhol78
Soundpack Amp power
« on: May 27, 2012, 12:09:50 am »
Recently installed an RNS510 to go with the Soundpack option the car has.
Questions are:
1) What power does the amp put out
2) Would a Pioneer double din with 4x50w be better than RNS with Soundpack?
3) Would the pioneer go through the amp if connected with the same iso block?
Offline Pashka
Re: Soundpack Amp power
« Reply #1 on: May 28, 2012, 11:56:55 am »
RNS has 4x20 watt amp.The Monsoon amp puts out 18W/ch into 4 ohms, and roughly twice that into 2 ohms. The two rear woofers are 2 ohms. So that's 18W * 6 + 36W * 2 = 180WPioneer would give better sound quality, but you would loose oem looking. Also, for external amp, you should buy extra cable for line- outs because Pioneer doesn't supply it with new HU. In my opinion, monsoon would work with Pioneer, but you would have to modify the cable.
« Last Edit: May 28, 2012, 12:01:04 pm by Pashka »
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
