Author Topic: FAO - anyone with Porsche 4 pots  (Read 4164 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: FAO - anyone with Porsche 4 pots
« Reply #15 on: May 30, 2012, 02:58:59 pm »
i have the NQSBBK with ferodo ds2500, no issues at present
DS2500 - isn't this primarily for track?
Do you have the shims on at all?
DaveB mentioned to me that the pad compound on the DS2500s have rubber in, so on track days when the pads get hot the rubber melts away and the pads fall apart  :rolleye:
his advice is Ferodos for fast road/light track, but if you're going heavy the Pagid RS4-2s.
PLANS: Stage 2+
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #16 on: May 30, 2012, 06:34:17 pm »
yup as Sub says, the DS is fine for fast road use but are no good for hardcore trackday action
« Reply #17 on: May 30, 2012, 06:35:27 pm »
The rs4-2 were fantastic when bedded in  :driver:
Offline jimk04
« Reply #18 on: May 31, 2012, 07:01:57 am »
Sorry guys....laptops died so on phone.
At muckipup...I am on 996 fronts over 330x28....so same width as what the caliper is designed for. Think I may try taking them out.
I am on Textar oe porker pads...squeal like a pig
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #19 on: May 31, 2012, 12:31:27 pm »
For the users of the nqsbbk:
It appears that Pagid doesn't sell the Pagid RS29 Yellow compound in the UK: http://www.pagid-brake-pads.co.uk/car-brake-pads/porsche-boxster.html
But this is sold in Germany: http://www.nimex-motorsport.de/?category=products;subID:183&sessID=q2fi40a40qr5t8scr333hfp890
So if you are after some great daily drive and track day pad look no further (not cheap though). As soon as my current Pagid RS 4-4 (second) pads need changing I will go with RS 29.
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #20 on: June 03, 2012, 12:11:48 am »
Jim sounds like you've got a sticky piston.
The seals are square in a rhomboidal recess, sounds like the piston isn't retracting when of the pedal.
Did you use some decent assembly grease on the seals and pistons when you nut them back together
Offline jimk04
« Reply #21 on: June 03, 2012, 12:59:03 pm »
Thanks Dave - that was a thought to be honest as I dont think I greased them on reassembly - I think I thought the fluid would lube them up :ashamed:
I have moved them in and out a few times manually - taking pads out and checking they are free, but it looks like I might take em to bits and lube them up.
could I use this Pagid Ceratec I have here now?
  • Trader - 2014
  • -Receive: 130
« Reply #22 on: June 03, 2012, 08:10:34 pm »
Errrrrrr no, that's for binding pads to calipers and keeping them quiet.....
You need the opposite...you need a lithium based grease, brakes international are selling it on eBay at the mo.
Alternatively take the seals out clean them using a clean cloth and then immerse them in seal conditioner for 30 minutes or new clean brake fluid for 90 minutes. Lithium grease is preferable.
I'd do them all pal, or if you're local pop in to mine and we can do it while you wait
Offline jimk04
« Reply #23 on: June 03, 2012, 11:13:44 pm »
Star man for the offer Dave but I'm a good way from you. I'm ok with doing it....just need to plan a time.to do it.
A 4 day weekend would be nice.....
.....errrr :stupid: :laugh:
