Author Topic: Look's like my front passenger door central locking system is screwed!  (Read 1328 times)
Offline sanj
  • -Given: 17
Tried to unlock my car this morning only to find the front passenger door won't open,did'nt help with the wife trying to open the door as well!I've done a quick google search and it seem's it's quite a common problem,you can hear the central locking opening then closing the door(2 click's)I managed to get it open by pressing the unlock/lock button on the inside like 50 time's and pulling the inside handle and it opened only to lock it's self the very next time I tried it,is it a dealer/vag specialist job or is there something that can be done? :ashamed:
Offline bakili
I had same issue on my MKV, I did spray some WD40 on lock, and it seems to fix it. Remove little rubber cover with lock picture located on the side of door, and spray WD40. 2 month now had no issues so far.
Offline sanj
  • -Given: 17
Thank's for the reply mate,tried that already,it worked for a few hour's and then did the same thing again,look's like it's off to the dealer's then as taking the door skin off to get access to the lock is a pain. :surprised:
Offline holepunch
Offline sanj
  • -Given: 17
Offline Matto
  • -Receive: 116
Have a look at my posts in this thread. I had exactly the same thing.
http://www.mk5golfgti.co.uk/forum/index.php/topic,48079.msg554184.html#msg554184
« Last Edit: May 28, 2012, 10:49:39 pm by Matto »
Offline sanj
  • -Given: 17
Have a look at my posts in this thread. I has exactly the same thing.
Thank's for all the help guy's will get to have a look when I get chance.Seem's like quite a common fault.
Offline holepunch
@ Matto,
Did you replace the module or the wiring and did the module require coding?
Offline Matto
  • -Receive: 116
Holepunch...the module I speak of is only the lock module. It just houses the door latching and locking mechanism. It's not the door control module for things like the electric windows etc.
