Author Topic: OEM Bluetooth coding help!  (Read 1162 times)
Offline lingenfelter
« on: May 29, 2012, 03:02:03 pm »
Hi everybody!
I would like your help here.
Today i installed an OEM BT kit "VW Bluetooth KIT 9W7 RCD RNS510 RNS 310 MFD iPhone ► 7P6035730G ► A2DP BT Audio".
I haven't done the coding yet.
My car has a MFSW and midline clocks.
Which coding should i use?
According to "http://www.my-gti.com/429/volkswagen-skoda-bluetooth-programming"
 "The controller soft coding should be set to 0000422"
-I can't understand which Steering Wheel Type should i use and why.
-Also , in the "0xx?xx: Installed Components" , what is the right one?
I would also like a help in the third step "Multi Function Steering Wheel – Voice activation (optional)".
-In the "0xx?xxx: Steering Wheel" section, what is the right type?
-In the "0xxxx?x: Board Computer / Cruise Control System (CCS)", what is the right one?
-And what about : 0?xxxxx: Driver-Assistance-Systems , 0x?xxxx: Vehicle Type , 0xxx?xx: Multi-Function Steering Wheel , 0xxxx?x: Cruise Control System (CCS) and Adaptive Cruise Control (ACC) and 0xxxxx?: Rear Wiper and Board Computer?
Thanks in advance! :party:
Offline mortygttdi
  • -Receive: 146
Re: OEM Bluetooth coding help!
« Reply #1 on: May 29, 2012, 08:49:06 pm »
I believe the 7P6 unit uses long coding so just run through it and pick out the ones that don't apply to you :happy2:
Darren
