Author Topic: washer fluid bottle  (Read 2147 times)
AA
washer fluid bottle
« on: June 03, 2012, 12:46:37 pm »
  Would like to fit the larger 5L bottle in place of the 3 or 3.5L bottle I have at the moment.
 Is there enough space to fit the larger bottle
  Is there a kind person who has the part number for the larger size pleeeese
Offline skard
  • -Receive: 245
Re: washer fluid bottle
« Reply #1 on: June 03, 2012, 12:57:35 pm »
Yes it is a direct swap.
Try 1K0955453S fot the 5.5L reservoir.
If you don't have headlamp washers, you may need to buy a plastic plug and rubber washer.
When I bought the larger bottle when retrofitting headlamp washers, the headlamp washer pump hole was pre-drilled. You'll possibly need to plug it then.
431955465A - seal, can't remember PN for the plug - it is 22 & 26 on the diagram when you order.
Offline skard
  • -Receive: 245
« Reply #2 on: June 03, 2012, 01:01:46 pm »
I recall my old reservoir having a few part number's that didn't correlate to a 5.5L one, to look at both the 3.6L and 5.5L look the same from the front, but the back end is deeper on the bigger bottle.
So if you're buying outwith the dealer then try get a picture.
AA
« Reply #3 on: June 03, 2012, 01:58:15 pm »
 Didnt expect a response so quickly and so helpful. Part numbers and ETKA diagram numbers.
  Many thanks Mr SKARD :smiley:
 I dont have washers as yet just gathering as much info as possible beforehand
« Last Edit: June 03, 2012, 02:00:47 pm by AA »
Offline skard
  • -Receive: 245
« Reply #4 on: June 03, 2012, 02:09:43 pm »
No probs.
Are you also fitting the low level sensor? This was part of the Kufatec lamp washer loom but can be put in seperately I believe.
Eddie-nl would be the man who could possibly make a loom for you.
AA
« Reply #5 on: June 03, 2012, 02:15:15 pm »
 Kufatec? Help :scared: :scared: (Im getting out of my depth) :signLOL:
Offline skard
  • -Receive: 245
« Reply #6 on: June 03, 2012, 02:20:22 pm »
Sorry mate going off on a tangent.
Kufatec are a German firm who make retrofit looms, so if you know you are putting in headlamp washers or just the sensor warning then you may as well get the sensor/loom etc and do it all in one go.
If you just want a bigger tank then ignore me!
It's this site you see, get an idea and watch it grow.
AA
« Reply #7 on: June 03, 2012, 02:26:32 pm »
 :happy2:  Found Kufatec. Spent the first couple of minutes looking at images before I found the
  Union Flag in the corner :stupid:
Offline skard
  • -Receive: 245
« Reply #8 on: June 03, 2012, 02:39:09 pm »
Have a search for Eddie-nl as he can make up some looms too
