Author Topic: Engine managment possible sports cat, VCDS results  (Read 1139 times)
Offline mano
« on: June 03, 2012, 05:24:22 pm »
Hello all, had a sports cat in for around 4000 miles, never had a problem, driving home however resently its been smoking a lot under hard accelleration, or so i am told.
results from scan are below,
2 Faults Found:
001056 - Catalyst System; Bank 1
               P0420 - 002 - Efficiency Below Threshold - MIL ON
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
personally i think it could be the sports cat is f*cked? however advice is please.
can i still drive the car without doing harm to the ecu, causing over fueling ect
cheers in advance
Re: Engine managment possible sports cat, VCDS results
« Reply #1 on: June 03, 2012, 06:04:36 pm »
See this thread for the second fault.
http://www.golfgtiforum.co.uk/index.php?topic=232256.0
Offline mano
« Reply #2 on: June 04, 2012, 08:15:54 pm »
Ok thanks. Anyone else got any ideas?
