Author Topic: HEP inlet manifold  (Read 1061 times)
Offline Dp_Ed30
HEP inlet manifold
« on: June 04, 2012, 03:43:42 pm »
hi guys, i am very vary close to ordering my METH kit and looking for ways to install it.
came across the HEP manifold here
http://uspmotorsports.com/product_info.php?cPath=26_357_40_46_94&products_id=820
but cant seem to find a huge amount on info.
my last car ran a EDS uprated inlet manifold and made a world of dirrence, my thoughts are as the k04 is pretty much maxing out would this alow me to make more use of the boost i already have at the same time as alowing a neat and accurate meth install.
thanks
Offline xht20
Re: HEP inlet manifold
« Reply #1 on: June 04, 2012, 10:57:52 pm »
I have it.
My advice is: if you will stay with K04, don't get it. It won't make a difference
If you go BT, get the Stage 1: same air volume as stage 2, but without the extra ports for meth and fuel. Using the extra injectors will require a lot of work and you risk ruining your car's reliability. And you will also have a CEL because it doesn't have flaps.
And for meth, use the "classic" solution, with BSH throttle pipe with slot for meth injector
