Author Topic: Bulb light on!!!  (Read 5349 times)
Bulb light on!!!
« on: June 04, 2012, 06:42:19 pm »
Well today I noticed the Bulb warning light On the dash.
I've been round the car checking headlights, sidelights, brakes, indicators, fogs, reverse, and interior and I can't see any blown bulbs.
I also checked the boot light and glovebox light.
Still the light is on the dash???  :confused:
Any ideas? :sad1:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Bulb light on!!!
« Reply #1 on: June 04, 2012, 06:56:32 pm »
Check registration plate lights
'07 Red manual
« Reply #2 on: June 04, 2012, 07:33:49 pm »
Nice one mate! I thought I had checked everywhere! :congrats:
I'll check em later on.  :wink:
Offline -blade-
    • Members Rides
« Reply #3 on: June 04, 2012, 08:51:10 pm »
Also - have you fitted any LED bulbs ? these can give intermittent bulb failure warning when in fact they are working just fine (measurement of resistance change makes the circuit think its broken)
'05GTI FSI Tornado Red | Leather | 18"BBS | lowered on Coilovers | TorqueTronix @260BHP | ITG intake | Forge DV | SS Downpipe | SS De-cat | Carbon Grille | HID's | Team Heko Deflectors | Ducted Fog Covers |
« Reply #4 on: June 04, 2012, 09:03:51 pm »
No mate, no LEDs.
Offline Little_Dave
« Reply #5 on: June 04, 2012, 10:18:08 pm »
It should come up on the dash what bulb has gone.... if you turn the ignition off and back on again it should bing at you and say which bulb to check/replace  :wink:
Dave
Offline -blade-
    • Members Rides
« Reply #6 on: June 05, 2012, 07:44:40 pm »
what was it in the end? a sneaky reg plate bulb?
Offline bakili
« Reply #7 on: June 05, 2012, 08:05:18 pm »
 I believe most German cars has bulb failure detection system works on resistance, it is quite likely to behave as you describe. The best that can be said is a bulb is about to fail. Happened to me once, warning light came on, before bulb failed, day later side bulb gave up.
It also could be loose bulb connection, have you recently replaced any bulbs?
« Reply #8 on: June 05, 2012, 08:59:46 pm »
Well on start up the bulb detection said it was the rear left brake light. However it still works fine....or so I thought.
It worked fine when checked with a neighbour, but tonight we checked again and it worked intermittently.
So it looks like the computer even detects bulbs on the way out  :happy2:
Offline Kalpsn2000
  • -Receive: 56
« Reply #9 on: June 05, 2012, 11:24:17 pm »
Interesting, good to know :happy2:
Offline drexel75
« Reply #10 on: June 06, 2012, 12:48:24 pm »
I've got the exact same problem. Only happens sometimes on start up, "Rear Left Brake Light Not Working", but by the time I get to the end of the road and touch the brakes the warning light goes out and the brake light works fine. Weird!!!!
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #11 on: June 06, 2012, 12:51:30 pm »
Mine done this with a sidelight, changed it and has been fine ever since. Now the passenger headlight has started doing it so now there's a good excuse to upgrade my headlight bulbs
