Author Topic: Rough prices for straight engine swap or engine rebuild  (Read 13791 times)
Offline Sammy
« on: June 05, 2012, 11:50:32 pm »
What prices are to be expected from usual garages to do a engine swap and specialists too?
Also same for rebuilds? If at a position to have to change which one is the best to go for?
GTI MK5 with all the gooodies
K04 power going on soon!
Re: Rough prices for straight engine swap or engine rebuild
« Reply #1 on: June 05, 2012, 11:53:38 pm »
alll depends what is up with the engine--but if your engine swapping put the s3 engine
Dsg steel
« Reply #2 on: June 06, 2012, 01:48:36 am »
Would also like to know how much it would roughly cost to fit an s3 engine to my dsg gti.
Anyone know what I'm looking at and who to take it to?
Billy
Offline Dp_Ed30
« Reply #3 on: June 06, 2012, 08:28:40 am »
last time i got a engine changed it was £350, its buying the bloody thing that costs a fortune.
i bought a engine with a gear box and clawed some back selling all the bits that i didnt need
Offline Sammy
« Reply #4 on: June 06, 2012, 11:06:32 am »
If I have DSG then can I buy a engine from a manual car and fit it on directly?
« Reply #5 on: June 06, 2012, 02:30:49 pm »
I suspect you'll want to get the car's ecu as well...
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #6 on: June 06, 2012, 03:39:59 pm »
If looking to go from a AXX or BWA (200bhp) engine to an BHZ or BWJ (S3 and Cupra, can't remember the code for the ED30) preferably you need the ECU an the 200bhp ECU won't support the 3,0Bar MAP sensor and softwarewise you might struggle to get the max from the swap keeping the 200bhp ECU  :happy2:
Over the top mod list ;o)
Offline Sammy
« Reply #7 on: June 06, 2012, 04:05:27 pm »
Say I get hold of a s3 engine I need the ecu from the right? And if it's a manual s3 would it go on to my DSG gearbox?
  • -Given: 243
  • -Receive: 154
« Reply #8 on: June 06, 2012, 05:50:18 pm »
No trouble in swapping the engine block itself. As i'm informed you need an ECU for a similar car. A Seat ECU shouldn't work in a golf, so ideally you need an ECU from a car of same type as your own, but i have not this confirmed.  :sad1:
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: June 06, 2012, 06:15:59 pm »
Any engine from any TFSi will go straight in and work with your current ecu even if the engine is from a DSG.  Just use all your old ancillaries and you wont have a problem.
Follow AKS tuning on Facebook
Offline Sammy
« Reply #10 on: June 06, 2012, 06:29:40 pm »
Alright but say I use my original ECU for the s3 engine or a golf r I would have boosting problems wouldn't I? Also an anyone confirm that a s3 ecu will work on a gti mk5?
  • -Given: 243
  • -Receive: 154
« Reply #11 on: June 06, 2012, 06:33:35 pm »
No boosting problem, you just can't use the MAP sensor
Offline Sammy
« Reply #12 on: June 06, 2012, 06:36:43 pm »
But I will have a k04 on that with s3 injectors?
Offline vRSAlex
  • -Receive: 253
« Reply #13 on: June 06, 2012, 06:45:14 pm »
You cant just swap ecu's as the ecu is coded to the dash.
Use your current ecu and get it mapped for the K04 and S3 injectors.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #14 on: June 06, 2012, 07:03:05 pm »
So using the origanal gti ecu will work fine, its just the map sensor wont work, which means changing it over for your own engine.
Anything else?
Silver is the way !
