Author Topic: Boost gauge wiring  (Read 746 times)
Offline RENNTAG
  • Premium Performance Parts
Boost gauge wiring
« on: June 06, 2012, 07:07:56 pm »
I have just fitted a newsouth boost gauge.
For wiring it in to the head light switch i followed the newsouth performance instructions and connected the red wire to position 8 of the connector and the black wire to position 3 of the connector.
This just put the side lights on permanantely. Does anyone know what im doing wrong or which wires i should connect it too so that the gauge lights up with the rest of the dash?
Offline RENNTAG
Re: Boost gauge wiring
« Reply #1 on: June 06, 2012, 08:33:14 pm »
Also what boost should i be expecting for a stage 2 ko3 with TBE
At the moment it peaks at 15-16psi and drops back to 11psi. Does that seem a bit low?
Offline RENNTAG
« Reply #2 on: June 07, 2012, 09:26:50 am »
Any help please?
Going to call the garage today about the boost pressure.
Offline KC_Gti
« Reply #3 on: June 07, 2012, 02:16:48 pm »
I've got a liquidgolf gauge installed and get peak of 22 psi I think on stage 2
Offline RENNTAG
« Reply #4 on: June 07, 2012, 02:21:35 pm »
Thanks for the reply.
Yes think thats what i should be expecting. The car drives really well so dont think there is a boost leak. Had the DV replaced at same time as it was mapped so shoulf not be a problem.
Got a feeling the hole in the port of the newsouth no buzz fitting T-piece is too small and is restricting the boost pressure to the gauge. The hole in the T-piece is tiny compared onto the hole on the gauge end.
Will take it off tonight and try and make the hole a bit bigger and see if that helps.
