Author Topic: Advice Req'd - RCD510 & MDI for Ipod  (Read 1598 times)
Offline schwartz
  • GT Sport TDI 170
« on: June 06, 2012, 09:24:06 pm »
Hello my friends, I'm looking for some help please  :happy2:
I have recently fitted an rcd510 in replacement of my rcd300 mp3. There are no issues at all with the h/u itself.
The problem has arisen since fitting an OEM mdi interface for using my ipod/iphone.
Basically, I am not getting any sound or information from the kit.
I have enabled the aux input through the h/u in the settings screen. The h/u recognises that something is plugged in to the aux port.
I have read on here about the can-bus interface, which may need upgrading, however my car is a 2008 model (build date february) so cant imagine this being the cause?
Is there something that needs enabling through VCDS?
Thanks in anticipation of your advice  :wink:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Advice Req'd - RCD510 & MDI for Ipod
« Reply #1 on: June 06, 2012, 09:30:08 pm »
Did you adjust the Aux-input volume level?
Offline schwartz
  • GT Sport TDI 170
« Reply #2 on: June 06, 2012, 09:34:38 pm »
Yep, done that buddy  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: June 06, 2012, 09:43:25 pm »
Is it just no sound or are you getting interference? Did you do the pin swap?
As in this link http://www.my-gti.com/1336/cd-changer-audio-sound-quality-problems-after-changing-head-unit
Offline schwartz
  • GT Sport TDI 170
« Reply #4 on: June 06, 2012, 09:51:20 pm »
I'm getting nothing buddy... no info, no sound. I havnt done the pin swap yet... will do it if need be (when I know if there is interference or not haha)  :laugh:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #5 on: June 06, 2012, 09:59:37 pm »
Sounds like you need to activate with VCDS, do you have it? If not check the register for someone close by
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html   :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #6 on: June 09, 2012, 06:02:40 pm »
What MDI interface cable are you using?
Where did you put the MDI interface loom in relation to the radio loom?
Does the iphone/ipod start charging when plugged in?
Offline schwartz
  • GT Sport TDI 170
« Reply #7 on: June 11, 2012, 07:43:09 pm »
Cable is OEM
One end of interface loom plugged in to standard loom and the other end in to h/u
Yes it does
 :happy2: :happy2: :happy2:
Offline schwartz
  • GT Sport TDI 170
« Reply #8 on: June 19, 2012, 07:46:38 pm »
Well, seems its my h/u...  :surprised:
I was under the impression that all rcd510's were the same?
The kit works perfectly with my mates rcd510, which has the same p/n as mine, but has 5 more pins on the back, weird??
So, looks like I need to get myself another unit  :sad1:
