Author Topic: RNS in Mk6 Problem  (Read 2586 times)
Offline Lyons
  • -Given: 18
RNS in Mk6 Problem
« on: June 08, 2012, 12:07:53 pm »
A mate fitted an RNS to his GTD and the volume controls on the mfsw aren't working, all the rest are however.
He hasn't got nav activated in VCDS yet, but surely the volume controls shouldn't be affected by that?
Any reason why they aren't working that we've overlooked?
Offline Geoffcapes
Re: RNS in Mk6 Problem
« Reply #1 on: June 09, 2012, 02:48:52 pm »
I had this issue in mine. I solved it by updating the firmware on the RNS but Becareful u don't brick the unit!
Shadow blue Scirocco, Apr stage 2, bcs TBE, forge pipework, led DRLs , H & R lowering springs, custom front bumper, colour coded side skirts.
Offline apples12
« Reply #2 on: June 09, 2012, 03:00:13 pm »
i'm pretty sure you have to activate 'BAP' protocol or something like that because of the new CAN interface for the steering controls in the mk6...
MK6 GT TDI  - CW - LUX pack
GONE
Offline mortygttdi
  • -Receive: 146
« Reply #3 on: June 09, 2012, 03:00:47 pm »
It sounds like its not coded in properly, it needs the BAP and short press in the nav activating
Offline Lyons
  • -Given: 18
« Reply #4 on: June 09, 2012, 05:52:51 pm »
Cheers for the replies, but it's randomly started working!  Still needs coded for the nav though.
He also had Bluetooth fitted prior to the RNS, but since adding it the screen and power has flicked between on and off for random periods of time. I got him to remove the Bluetooth loom and the RNS has stopped going off, so at least it's 100%. It sounds like there's a dodgy connection or 2 in the loom. Could this be possible? Would it be safer just getting another from Kufatec?
Offline alexperkins
  • -Receive: 99
« Reply #5 on: June 09, 2012, 06:00:36 pm »
Sounds like a loom failure if the RNS works fine without the bluetooth
What kit is it?
Offline Lyons
  • -Given: 18
« Reply #6 on: June 09, 2012, 06:08:37 pm »
I can't remember. It's a VW module.
I assume Kufatec are the only ones that make looms?
Offline alexperkins
  • -Receive: 99
« Reply #7 on: June 09, 2012, 06:11:11 pm »
Unless you are using the loom that came with it, it'll be a kufatec loom most likely.
Offline Lyons
  • -Given: 18
« Reply #8 on: June 09, 2012, 06:34:15 pm »
Are they known to give bother?
Offline alexperkins
  • -Receive: 99
« Reply #9 on: June 09, 2012, 06:35:56 pm »
If not fitted securely they can
Offline Lyons
  • -Given: 18
« Reply #10 on: June 14, 2012, 07:06:07 pm »
Complete nightmare!!
Loom removed and the RNS is 100% one day, then flicks on off and the mfsw doesn't work the next!
He still hasn't got BAP activated yet. Does this sound like that could be the answer?!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: June 14, 2012, 08:27:59 pm »
bap and shortpress need to be ticked in a mk6
Cluster and Key coding
Location Great Yarmouth
Offline Lyons
  • -Given: 18
« Reply #12 on: June 14, 2012, 10:32:20 pm »
Is that done in VAGcom Eddie?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #13 on: June 14, 2012, 10:40:50 pm »
yes, it is in the rns long coding.
Offline Lyons
  • -Given: 18
« Reply #14 on: June 14, 2012, 10:45:25 pm »
Will that make sense to someone that's familiar with VAGcom?! I've another mate that does a fair bit, but I don't think he's coded an RNS.
