Author Topic: ITG intake heat shield  (Read 4505 times)
Offline mdmay
  • -Given: 38
« on: June 09, 2012, 10:42:23 pm »
Hi all,
thought i would get your opinions on the ITG heat shield (foam crappy thing). I have been running my car with this in place for a days now after previously fitting the kit with it off. I have found that with if fitted the car seems less responsive. I just thought i'd see what everyone else's opinions are and any alternative ideas for a heat-shield which might incorporate the OEM intake scoop
Mike
Regards,
Mike
Re: ITG intake heat shield
« Reply #1 on: June 09, 2012, 11:11:57 pm »
 I recently removed mine as it was looking tatty.
I think it improved responsiveness but could well be placebo effect.  I was without my car for a few weeks so it was bound to feel rapid after the wife's Lupo lol
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: June 09, 2012, 11:20:39 pm »
i thought then when out on the open road, yes will be more responsive without, but if you are sat in traffic will help keep heatsoak to a mimimum with it fitted so depends whether you get caught in rush hour traffic much i have mine fitted at mo but may take off.
Offline mdmay
  • -Given: 38
Re: Re: ITG intake heat shield
« Reply #3 on: June 10, 2012, 01:41:27 pm »
I have removed my heat shield again and it definitely seems to pull better without it.
Regards,
Mike
Offline gazon69
« Reply #4 on: June 10, 2012, 06:54:47 pm »
When i bought mine i fitted it and thought that looks crap. Tbh i cant see where cold air could get in as it blocks off the grille vent that pushes cold air in, so i took it straight back off. I couldn't tell you how it drove with it on as i never tested it. Seems ok without it though. :happy2:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #5 on: June 10, 2012, 07:01:04 pm »
itg are the masters though, they have made it part of the kit for a reason.
what about that foam bit that goes across the battery? what is that meant to do? just stop dirt landing on the filter?
Offline synchronize
« Reply #6 on: June 11, 2012, 10:03:22 am »
If you're sat in traffic will you not get heat soak through the hoses that run around the engine anyway?
When I fitted mine about a month ago, I had problems getting the bonnet to close flush, especially with the foam bit.
I took the heat shield off and it defo pulls better. Sometimes seems a bit lumpy with the heat shield on - maybe I haven't fitted it correctly.
Offline mdmay
  • -Given: 38
« Reply #7 on: June 13, 2012, 08:09:17 pm »
Silicone is not a great conductor of heat so I would not have thought the heat soak to be too much of an issue.
Regards,
Mike
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
« Reply #8 on: June 13, 2012, 08:50:20 pm »
Runs outside to take the foam off  :grin:
www.distinctdetailing.co.uk
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #9 on: June 13, 2012, 09:22:43 pm »
Ok took mine off and yes it seems better  :popcornsoda:
Offline Jussa
  • Bicester
« Reply #10 on: June 13, 2012, 10:11:49 pm »
 :signLOL:, this sounds like an old wives fish tale!!!
Surely ITG would know whether that foam should be there or not????
Mine is purely foam, but I have seen some with a metal of some sorts stuck on the foam????
 :confused:
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #11 on: June 13, 2012, 10:15:44 pm »
 :confused:
Justin were talking about the metal heatsheild that has foam on the back of it, it will be just behind the itg filter cone, don't go ripping the filter apart  :signLOL:
And yes itg have put it there for a reason so I'm not sure why it's better, I'll call itg Tomoz and ask the question, could just be a part in development that they put there and they haven't tried it without? I'll ask them  :drinking:
Offline Jussa
  • Bicester
« Reply #12 on: June 13, 2012, 11:06:24 pm »
 :confused:
Oh, I'm talking about the foam piece that sits sort of to the left and stretches to the right above the intake???   :confused:
Offline mdmay
  • -Given: 38
« Reply #13 on: July 31, 2012, 11:05:45 pm »
Resurrection of dead thread but have definitely found a positive improvement leaving the crappy foam thing off
Sent from my GT-I9300 using Tapatalk 2
Regards,
Mike
