Author Topic: Clutch slow to return  (Read 4022 times)
Offline mk5craig
« on: June 11, 2012, 11:45:19 am »
Hi all,
Driving the car the other day and changed gear but the clutch was slow to return, it was fine again but has since done it again,
Anyone had similar problems or idea what it could be?  Slave cylinder?
Thanks Craig
Offline Johnny_tro
Re: Clutch slow to return
« Reply #1 on: June 11, 2012, 07:36:07 pm »
mine did thos the other month buddy. I left it and left it and cost me more. Sounds like clutch wear. Get it checked. I left mine and ended up having to change the clutch and the fly wheel.
Offline apples12
« Reply #2 on: June 11, 2012, 09:54:35 pm »
I'd probably look into checking for an air bubble/leak in your brake fluid lines/system before you go down the route of changing clutch/flywheel...
check fluid levels, and if you havent had your annual brake fluid change done - get one arranged by your mechanic/dealer!
MK6 GT TDI  - CW - LUX pack
GONE
Offline No-fear
« Reply #3 on: July 11, 2012, 09:11:50 am »
Get your clutch fluid bled from the nipple on the gearbox.
Got mine done last month, thought I had to replace the clutch and flywheel, the fluid was grey, clutch is sweet and smooth now.
Saved me a little fortune and hassel.
Whilst changing it get it bled at the hubs also, fresh fluid all round in the pipes.
It's better to have Raced once in your life than be a Spectator for all of it.
Offline Moz
« Reply #4 on: July 11, 2012, 02:51:23 pm »
As others have said, could be air bubble, or also sticky release bearing?
Offline Luka
« Reply #5 on: July 20, 2012, 10:17:37 pm »
Mine's doing this. I've heard a lot about slave cylinders but I think I'll try the fluid route first. Gears are a bit notchy and sometimes it even jolts when put into first!
Sold - 2006 Tornado Red GTI 3dr
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #6 on: August 31, 2012, 12:06:02 pm »
any update on this luka?
my clutch has been slow to return twice now, once after dyno session yesterday on way home?
