Author Topic: how do i check the dsg torque limiter with vagcom?  (Read 2206 times)
Offline jedi-knight83
  • -Receive: 41
« on: June 12, 2012, 12:09:01 pm »
Sorry for another thread.... but im borrowing a cable this afternoon to test my car and do a dsg reset to try to get to the bottom of my post cear change lag in power...
Someone said to record a 'measuring block' on vagcom to see if the dsg torque limiter was causing my lag...
Can someone kindly give me a few tips on how to do this.
  • -Receive: 41
Re: how do i check the dsg torque limiter with vagcom?
« Reply #1 on: June 12, 2012, 03:49:42 pm »
anyone... just about to head out to use the vag com cable.
« Reply #2 on: June 12, 2012, 04:45:09 pm »
Do you know how to bring measuring blocks up?
« Reply #3 on: June 12, 2012, 04:48:20 pm »
http://www.ross-tech.com/vcds/tour/m-blocks.html
You will need to scroll through the blocks to find the appropriate one.
Offline kevinm
  • -Receive: 25
  • No. 728
« Reply #4 on: June 12, 2012, 07:31:43 pm »
The correct block is in the 120's. I cant remember exactly. Try 121 and 125 first.
With the block open go for a 3rd gear pull and see it it says the limiter is engaged.
