Author Topic: Passenger Air vent Driving me Nuts  (Read 2724 times)
Offline ianv5
« on: June 13, 2012, 08:34:00 am »
As above my passenger Airvent, the one nearest the nearside window has started to rattle very slightly but is driving me nuts. Can anyone help me on how to cure this?
It seems to be coming from the vent surround as it stops when I put pressure on it.
MPS
Re: Passenger Air vent Driving me Nuts
« Reply #1 on: June 13, 2012, 08:45:32 am »
The vents nearest the windows are an interference fit and as such just pull out, no screws holding it in. See if anything behind it rattling against it like a wiring loom or summat.
Offline ianv5
« Reply #2 on: June 13, 2012, 11:34:26 am »
How do you pull it out without breaking anything?
MPS
« Reply #3 on: June 14, 2012, 11:59:59 am »
Wedge it out with something thin and plastic to help you
MPS
« Reply #4 on: June 14, 2012, 10:59:10 pm »
Any luck? It really doesn't take much pulling, you'll be surprised.
Offline ianv5
« Reply #5 on: June 17, 2012, 08:14:34 pm »
Came out dead easy :happy2:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: June 17, 2012, 08:17:24 pm »
Did you cure the problem?
Silver is the way !
AA
« Reply #7 on: June 17, 2012, 08:21:26 pm »
 I had the same problem with the drivers side and used double sided stickytape.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #8 on: June 17, 2012, 09:00:40 pm »
I take it, using double sided sticky tape holds it in place rather than it moving about
Silver is the way !
Offline ianv5
« Reply #9 on: June 18, 2012, 08:53:18 am »
Not yet spent all weekend at the Moto GP at Silverstone, will fix this week along with the squeak I am getting from the centre dash!
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #10 on: June 18, 2012, 12:06:50 pm »
I thought my passenger vent was the cause of my annoying rattle, turned out to be a screw. If you open the passenger door and pop off the side access panel that is on the side of the dash there is a screw at the top that works loose. Tighten that up and hopefully voila! There is a thread on here somewhere all about it-which is how I found out about it
MPS
« Reply #11 on: June 18, 2012, 12:28:20 pm »
The screw in the exact same location on the drivers side is loose as well I found
Offline ianv5
« Reply #12 on: June 18, 2012, 01:20:45 pm »
Will check it out :happy2:
Offline ianv5
« Reply #13 on: June 19, 2012, 08:30:04 am »
Result :happy2: I took the side panel off and yes I had a loose screw!!! Tightened up and no rattle. Would suggest that in most cases this is the culprit and not the vent rattling.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #14 on: June 19, 2012, 12:14:55 pm »
Happy days   :jumpmove:
