Author Topic: K04 to K04 conversho help pleaz  (Read 686 times)
Offline neverbackdown
« on: June 13, 2012, 11:24:38 pm »
hay guys, im doing a k04 convershon on my seat leon tfsi mk2 200ps.
so far i have got.
k04 turbo
s3 injectors
autotech internals
itg induction kit (this is on my k03 at the minit, do i need a diffrent pipe to fit the k04, for the dv relocashon pipe?)
3" down pipe and decat
twin intercooler
s3 turbo discahrge pipe
forge Fmfsitv Dump valve ( is this even compatable with the k04 relocashon?)
im a bit stuck now tho, what elss do i need ( part numbers or webpages with ther right item would be grate)
should i get a ome dv relocashon or should i order the apr or simlure relocashon ( what apr kit would i need ?) where can i order it from?
when i fit the autotech internalss should i change anythink elss?
any help what so ever would be gratfull
cheers guys chris
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: K04 to K04 conversho help pleaz
« Reply #1 on: June 14, 2012, 06:35:23 pm »
1 x Air Pipe (IC to IM) (1k0 145 770 P)
This bit fis on the front for your dv
Yes you will need some kind of pipe work for your intake.
The search engine will be your friend here...
Just type in KO4 Conversion, there will be loads of threads.
The Dv relocation kit you need to get most of the parts from the dealers, or second hand on here!
Try addng parts into the wanted section, just my 2cents worth
Silver is the way !
