Author Topic: Whiteline anti rollbar  (Read 2161 times)
Offline dan930
  • -Receive: 56
« on: June 15, 2012, 11:17:39 pm »
Anyone tried the whiteline 24mm rear rollbar?? Might be thinking about getting this as dpm performance sell it for £165
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline Jimbo_h
Re: Whiteline anti rollbar
« Reply #1 on: June 17, 2012, 12:02:25 pm »
Yep, I've got both front and rear but had the rear fitted first (farb 6 mths after). Defo worth doing, the rarb makes turn in a lot sharper, gets rid of nasty under steer at road speeds. Can't compare it against other arbs out there as its the only after market one I've tried.
CW MkV GTI | DSG | Driver Motorsport tune | HPFP | SPM downpipe | Sach performance coilovers | Volant CAI | 18" Oz Ultraleggeras | SPM ARBs
Offline dan930
  • -Receive: 56
« Reply #2 on: June 17, 2012, 04:22:33 pm »
Cheers mate,Anyone else has got this fitted
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline daz_pd
  • My VRS
« Reply #3 on: June 17, 2012, 07:54:08 pm »
havent tried any others, but noticed the benefits from this immediately, pushes the nose of the car less now and just turns in
Offline dan930
  • -Receive: 56
« Reply #4 on: June 17, 2012, 08:06:18 pm »
Another silly question before I order..did the car feel more planted with the rear roll bar fitted??
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline Jimbo_h
« Reply #5 on: June 17, 2012, 10:05:03 pm »
Yes to certain extent but now I've had the front ARB fitted it feels properly planted. If I'd known how it would feel with both I'd have got both fitted at the same time.
Offline mkviken
« Reply #6 on: June 22, 2012, 12:17:33 pm »
i just ordered a whiteline rear sway bar.
i will do the front when i can be arsed but the front is a bigger job and ideally needs a lift. the rear is easy to fit and makes the biggest difference.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #7 on: June 25, 2012, 12:30:33 pm »
The rear is easier to fit but it makes no sense unless you buy the front one also.
By fitting the rear ARB you will make the car lose grip at the back sooner than it looses grip in the front. But the car would/should be even slower than stock (loosing grip sooner than stock) on many occasions.
My advice when buying ARB's is go for both front & back.
