Author Topic: How to guide  (Read 843 times)
PSW
How to guide
« on: June 18, 2012, 09:22:50 pm »
Done a search and can't find.... So how do I take my clocks out to see the code on the back.. Cheers in advance  :happy2:
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: How to guide
« Reply #1 on: June 18, 2012, 09:37:52 pm »
I believe you lower the steering wheel, pull the plastic bit under the clocks with the fabric/leather attached to it and it has 2 clips, 1 either side, then undo the 2 screws and then pull out the clocks (I believe that's what Eddie NL did with mine)
Then the reverse to put them back. Just make sure you have a magnetic bit otherwise if you drop the screw it means taking the underneath of the dash apart
Offline Johnny_tro
Re: How to guide
« Reply #2 on: June 18, 2012, 09:40:49 pm »
Correct  :happy2:
Really easy, remove the small plastic panel on the lower part of the clocks - just pulls off. Behind this you will find two screws. Unscrew these and the clocks simply slide out
Offline apples12
Re: How to guide
« Reply #3 on: June 18, 2012, 10:27:17 pm »
be reeeeeeeeeeeeeeaaaaaally careful when you pull the fabric/leather part attached to the top of the steering wheel - those two barstewards clips fly have a habit of flying around everywhere and scratching up the face of your clocks/instrument cluster! also helps if you pull the steering wheel out all the way and keep a finger under the screw ready for when it inevitably drops down!
MK6 GT TDI  - CW - LUX pack
GONE
PSW
Re: How to guide
« Reply #4 on: June 18, 2012, 10:48:49 pm »
Cheers for replays guys much appreciated  :congrats:  have a look tomoz  :happy2:
