Author Topic: Sat Nav - Aux, but where's the Aux in?  (Read 6899 times)
Offline Mk5 GTian
  • -Receive: 37
« on: June 18, 2012, 10:43:46 pm »
My new 55 plate Laser blue that I pick up on Thursday has a lot more kit on it than my poverty spec Shadow blue.
It has SatNav, and one of the buttons is AUX, but for the life of me I couldn't find an Aux In point to connect my ipod. Do I need to buy something else?
As usual,  :confused:
vw55raz
Re: Sat Nav - Aux, but where's the Aux in?
« Reply #1 on: June 18, 2012, 11:20:52 pm »
Yes you need an aux input cable which goes into the back of the unit. You can get them off eBay or kufatec website.
Offline bushypad
  • -Given: 18
« Reply #2 on: June 19, 2012, 01:40:06 pm »
Yeh I found the same thing but have no idea how to get into the back of the unit?!
vw55raz
« Reply #3 on: June 19, 2012, 02:02:44 pm »
What is the model of the satnav?
Offline bushypad
  • -Given: 18
« Reply #4 on: June 19, 2012, 02:51:01 pm »
Its MFD2
Offline Mk5 GTian
  • -Receive: 37
« Reply #5 on: June 19, 2012, 05:08:59 pm »
So is mine, MFD2.
Does anyone have the link for the right cable please?
Offline dry664
« Last Edit: June 20, 2012, 10:56:34 am by dry664 »
Offline Mk5 GTian
  • -Receive: 37
Offline Mk5 GTian
  • -Receive: 37
« Reply #8 on: June 20, 2012, 05:00:51 pm »
Does anyone know how to get the cable into the back of the unit?  :confused:
And then into the glove box?  :confused:
Offline alackofspeed
  • -Receive: 24
« Reply #9 on: June 20, 2012, 10:06:34 pm »
It's all pretty easy.
Ideally to route the cable into the glovebox you'll want to remove the glovebox, so you can fasten the cable back and avoid rattles. The glovebox has torx screws on the underside, along the top, and one cheeky one behind the cover above the ashtray. Undo all of those, then the glovebox comes out, but watch out for the wire connections to the glovebox light, switch, and footwell light. You also need to disconnect the small rubber air hose.
Radio is also easy. You'll again be working with torx screws, along with a stiff but relatively thin trim lever. I use a tyre lever, which by luck is especially pointy yet stiff (designed for downhill tyres...). You start at the top of the centre console, and gently lever out the large diffuser. You then undo the single torx screw to remove the air damper. You then undo 2 torx screws that hold the twin air vents, and gently lever up the bottom of the vents either side of the radio (towards the top). Now gently usher the vents up and away from the dash.
With the vents removed, you now gently and progressively lever out the radio and heater control infill trim. This will expose the 4 torx screws for the radio. Remove these and the radio slides out.
It really is easy to remove the radio - you'll take a while the first time as you learn the force required to remove the trim, but it'll take 5 minutes the second time.
There are probably some how-tos knocking about with pictures, if you want more clarity.
Offline Mk5 GTian
  • -Receive: 37
« Reply #10 on: June 21, 2012, 05:20:05 pm »
Thanks, I'll try and get hold of a trim lever.  :happy2:
  • -Receive: 24
« Reply #11 on: June 21, 2012, 10:19:43 pm »
Goes without saying that it should be plastic to avoid damage. Also you might want to remove the heater controls, as it's quite easy to catch them with the radio when extracting the radio.
Offline Mk5 GTian
  • -Receive: 37
« Reply #12 on: June 22, 2012, 06:43:24 pm »
I couldn't wait to get it done so took it down to 001 Mobile in Hersham Village and they fitted it for fifty quid. Saves me messing it up anyway!  :signLOL:
