Author Topic: Fiscon Bluetooth anyone got it, worth it oR oem opinions  (Read 1155 times)
Offline Eccleshall
  • My Ride: 2007 Silver Edition 30 - No. 768
« on: June 20, 2012, 12:06:51 am »
.... Anyone got it? Really woRth it I've bought on but not sure iF I'd ratheR have oem
Offline edd666999
  • -Receive: 89
Re: Fiscon Bluetooth anyone got it, worth it oR oem opinions
« Reply #1 on: June 20, 2012, 03:08:52 am »
why do yoU have random Capitals when You typE? is it a secret code   :grin:
 :grin:
Offline apples12
« Reply #2 on: June 20, 2012, 04:35:11 am »
i've got the fiscon Basic bluetooth kit - love it!
cheaper than the OEM kit, easier to install than the OEM kit - just a box, the loom that goes between the factory plug and the radio and the mic and thats it!
integrates with the RED MFD, also gives you the added bonus of the E-MFA, so you get number of litres left, boost, oil temp, speed and a few other bits and pieces assuming its supported by your engine. sound quality is superb, also supported A2DP with my old blackberry Bold 9780 without a single issue whatsoever, just pressed play on that and it came through in the car, now also supports it on my galaxy nexus!
i believe the difference between the basic and the basic plus kit is the basic plus allows you to see the address book on the RNS510 - i didnt require this function and i got the 'Basic' version kit very cheap off ebay.de so opted for that!
good luck!
MK6 GT TDI  - CW - LUX pack
GONE
Offline Eccleshall
« Reply #3 on: June 20, 2012, 08:48:29 am »
EDD666999 - I apologise for the capitals was on my iPad in bed n it was late, sorry mate.
APPLES12 - Cheers for the info mate, Sounds like I've made the right choice! I've got the basic plus one (not that it make much difference) whats the sound quality like? and where have you mounted your mic?
retrofit hard to do? thinking about doing it once i get some xenons
« Last Edit: June 20, 2012, 02:26:40 pm by Eccleshall »
Offline apples12
« Reply #4 on: June 20, 2012, 02:40:25 pm »
Hi,
the retrofit is really really easy...
all you've got to do is take out your radio/RNS
unplug the quadlock going into the back of that, secure the fiscon box round the bottom somewhere, i dropped mine behind the air conditioning controls, then later moved it to behind the gearstick when i had the entire centre console out (this is a bit 'overkill...behind the AC controls is sufficient)
then you've just got to feed the microfone wire down the A-pillar, behind the fuse box, behind the steering column and it comes out behind the stereo, its self explanatory when your in the car, i've got mine mounted just by where the little 'airbag' label/badge is on the A pillar
make sure you leave the microfone up there and feed the plug through! it'll be easier than trying to feed the microphone through all the wiggly bits!
then plug it in and thats all you've got to do!
have you got an RNS510? how much did the fiscon set you back?
GONE
Offline Eccleshall
« Reply #5 on: June 20, 2012, 04:15:37 pm »
Yeah mate, erm around £250 i think off ebay maybe a little bit more might have been more £270, Yeah got a RNS510 as well, cheers for the advice, got the genuine receipt with it, the the guy paid well over £350 originally i think
R32UK
« Reply #6 on: June 20, 2012, 07:49:12 pm »
I have the fiscon also.. great sound quality, and easy to fit (not that I would know)  :happy2:
Offline rob_e
  • 2012 vRS Octavia
    • vRS blog on Pistonheads
« Reply #7 on: June 20, 2012, 08:31:05 pm »
very happy with my fiscon, works just like oem - i'm a lazy git so i got richter sport in MK (importer) to fit it for me.
the next car will get one too.
Offline Eccleshall
« Reply #8 on: June 20, 2012, 08:37:01 pm »
That's where the one I bought off eBay was originally purchased
