Author Topic: Fitted RNS510 - problems  (Read 1905 times)
Offline Eccleshall
  • My Ride: 2007 Silver Edition 30 - No. 768
« on: June 22, 2012, 08:42:29 pm »
Hi
I've just fitted my rns510 and I'm having a few problems
1. The CD plays really fuzzy
2. I can control the volume on the MFSW but can't chane radio station using the arrows
3. My SD card won't read now I don't know of this is because it may be too large it's 32GB
I thought I coded it propperly through vagcom but mate not :/
Help
Much
Appreciated
Jack
Offline Squeeguk
Re: Fitted RNS510 - problems
« Reply #1 on: June 22, 2012, 09:00:21 pm »
1. Did you do the wiring change for the CD player? I can't recall which pins to change around, but a google should point you in the right direction. This should solve the sound issues.
Here you go:
http://www.mk5golfgti.co.uk/forum/index.php?topic=34251.0
2. Which MFSW buttons do you have? Not sure if there is an issue on the older style buttons. I am sure somebody with more knowledge will be along shortly.
3. Which version of RNS do you have? As far as I recall, the older versions were limited for SD card size. Try using a smaller card, say 8GB and see if that works?
and here:
http://www.mk5golfgti.co.uk/forum/index.php?topic=36999.0
« Last Edit: June 22, 2012, 09:05:28 pm by Squeeguk »
Offline Eccleshall
« Reply #2 on: June 22, 2012, 10:02:34 pm »
No I shall do that in the morning I remebered that afterward, I've seen it online somewhere before,  it's a 2008 1.9TDI bluemotion the steering wheel has 4 buttons each side and is standard leather,
I think it's a version B because the code on the top end in B but not entirely sure
Thanks for the links I'm on my iPhone at the moment, so when I get to te computer il check them out  :happy2:
Jack
« Reply #3 on: June 22, 2012, 10:09:54 pm »
Jack
Hi mate, you need the firmware disc to upgrade to a C version or higher. This will then allow you to use a SDHC card (above 2GB)
I think 2GB is the max on a B version??? Could be 4GB though  :ashamed:
« Reply #4 on: June 22, 2012, 10:11:38 pm »
Did you say you was in Bradford?
Offline Eccleshall
« Reply #5 on: June 22, 2012, 10:14:32 pm »
I'm actually down south at the moment at my dads in Hertford, and my mums is about 30 mins from Bradford called skipton
« Reply #6 on: June 22, 2012, 10:27:04 pm »
Darren is in Leeds and I'm sure he won't mind upgrading your RNS firmware. He can also put the very latest maps on and all the points-of-interest and speed cameras.  :happy2:
He is a top bloke  :notworthy:
Send him a pm mate   :wink:
His forum name is MortyGTtdi.
Offline Eccleshall
« Reply #7 on: June 23, 2012, 11:10:53 am »
cheers mate i shall be in contact with him as i got to go to leeds to sort my Private plate out hopefully could end up killing two bird with one stone :)
