Author Topic: Oil Temperature Question  (Read 6293 times)
Offline Mackie1
  • -Given: 22
« on: June 23, 2012, 01:03:37 am »
Hey foks can anyone confirm the optimum (or correct/normal) oil temperature for the Tfsi engine? The figure of 90 degrees has been mentioned but I've been unable to establish whether that's Celcius or Fahrenheit?! Thanks in advance.  :wink:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Oil Temperature Question
« Reply #1 on: June 23, 2012, 01:20:27 am »
less than 120 is okay.
There is a hidden display to find out what temp your oil is running at, i will try & find out the the numbers you need to find this out
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #2 on: June 23, 2012, 01:31:39 am »
15.0
Hit & hold econ button with the button to vent the windows at the same time, this will give you like a secert dash display, turn the temperature gauge to the right to 15, where your temp is displayed the oil temp will be shown...
Hope that helps M8ty  :happy2:
Silver is the way !
Offline Mackie1
  • -Given: 22
« Reply #3 on: June 23, 2012, 09:23:36 am »
Thanks Neil. Was already aware of how to access the temp reading through the aircon controls but it was the actual ideal oil temp figure that I was after.  :wink:
Offline craig_t
  • Craig
« Reply #4 on: June 23, 2012, 09:31:21 am »
Whaaaaaaaaat! I never knew this!!! So it will display oil temp in the temp display yeah
« Last Edit: June 23, 2012, 09:33:04 am by craig_t »
Admin notice, sig pic removed for being to big.
Offline Janner_Sy
  • -Receive: 113
« Reply #5 on: June 23, 2012, 09:37:49 am »
optium temperature is something like 87degreesC.  Upper limits of safety are 120-130degrees.
Offline craig_t
  • Craig
« Reply #6 on: June 23, 2012, 10:40:41 am »
Is there any other secret gauges I should know about guys!?!
« Reply #7 on: June 23, 2012, 10:43:33 am »
When pushing along the motorway I usually see temps of around 100C...
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #8 on: June 23, 2012, 12:22:13 pm »
15.0
No no no no!!  I fell for this one, it isn't the oil temp! That is the heater / air con diagnostics screen and does not show the oil temp. It gives you air con compressor speed at 15.0 IIRC. if you watch it it doesn't change.
Sorry guys  :love:
Offline craig_t
  • Craig
« Reply #9 on: June 23, 2012, 12:35:16 pm »
I think it's 0.0 on the heater side gives oil temp on the right display.
Offline Mackie1
  • -Given: 22
« Reply #10 on: June 23, 2012, 01:56:35 pm »
Thanks guys.  :happy2:
Offline Frenzy
  • -Receive: 29
« Reply #11 on: June 23, 2012, 02:22:57 pm »
I understand oil, oil temperature, optimum oil temperature, air con, air con buttons, econ mode for air con and air con display. I understand my car has buttons i can push and knobs i can twiddle. I also understand what the number 15 is and also have comprehension of 0.0...
However I have no feckin clue what you lot are on about! Anyone got any pictures or a video link explaining the above?!  :signLOL:
« Reply #12 on: June 23, 2012, 02:36:26 pm »
Forget all the knob twiddlling  :evilgrin: and get yourself a Polar FIS advanced to get the oil temp readout and much more...
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #13 on: June 23, 2012, 04:21:10 pm »
The air con display will not tell you oil temp (on any number). It's a myth  :surprised:
It tells you features of the air con, ie compressor speed. Only thing worthwhile on that display is the cars actual speed (19.1??) which the system uses to work out how much fan speed to use.
Trust me  :grin:
Been discussed several times on here. . . .
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #14 on: June 23, 2012, 05:22:11 pm »
what he said above!
Paul
