Author Topic: S3 Intercoolers  (Read 5501 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
S3 Intercoolers
« on: June 23, 2012, 07:33:18 pm »
Whats the deal with the S3 Intercooler...
1) Does it need to be the metal end tank one?
2) Whats the order of the radiators/coolers positions from front to back?
3) Will the S3 unit cope with stage 2/2+ or is it better to go aftermarket?
4) Is there a similar spec one on the Golf/Scirocco R? Is this the only reason these cars push more bhp on stage1 /2/2+
5) If I see a THS/Pro Alloy unit for an S3 will it fit the Golf Edition 30...
6) What else is needed?
Cheers,
Dom
Diesel Daily Hack.
Offline DFish
Re: S3 Intercoolers
« Reply #1 on: June 23, 2012, 08:39:50 pm »
Hopefully what I'm about to post ins't all crap. :)
1, they made them with both plastic and ally end tanks. Both should be good.
2, I'd think its AC, Intercooler then rad.
3, Yes it should cope with Stage 2/2+
4, The next up from the S3 I think are the APR/THS units.
5, It should do as they are all based on the same measurements.
6, Might need to replace/swap the pipes going to it.
Fish (waiting to be shot to bits)
Offline GarethB
Re: S3 Intercoolers
« Reply #2 on: June 23, 2012, 08:46:00 pm »
Have you considered a twintercooler Dom?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: S3 Intercoolers
« Reply #3 on: June 23, 2012, 08:47:18 pm »
1, Both. The Alloy ones seem to be more desirable and it's what i have on my Octy. The newer ones (iirc from 2010 onwards) are plastic ends.
2, Aircon, Cooler, Radiator in that order
3, I ran Stage 2 & Stage 2+ on my vRS with it no problem. I know others have run it on ED30's at Stage 2/2+ too
4, The Golf R/Rocco R have the Plastic end version iirc.
5, Yes
6, You need the S3 Cooler pipes and you may also need an adaptor to fit to the Turbo Discharge pipe. I can't remember what year they changed the position of the fitting lug.
Or
What he said  :laugh:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: S3 Intercoolers
« Reply #4 on: June 23, 2012, 08:54:25 pm »
Quite fancy one of these, so may have to wait till next year...
http://www.proalloy.co.uk/cgi-bin/sitewise.pl?act=det&pt=&p=1057&id=proalloy
Don't fancy the twintercooler... :indifferent:
Diesel Daily Hack.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: S3 Intercoolers
« Reply #5 on: June 23, 2012, 08:57:33 pm »
Are you planning on running big bhp?
If you're not the S3 Cooler will easily cope with the circa 330bhp of Stage 2+ ED30 and will save you about £300 in the process.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: S3 Intercoolers
« Reply #6 on: June 23, 2012, 09:08:51 pm »
Haha you never know... just like to use the best parts I can just in case... and as it's a pig to do, I don;t wanna pay for labour twice if you get me...
Diesel Daily Hack.
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: S3 Intercoolers
« Reply #7 on: June 23, 2012, 09:44:12 pm »
have you looked at Airtec intercoolers?
someone said they're quite well regarded by Ford drivers, and they've now started making stuff for VAG
also Pro-Alloy. apparently the same size/ability as THS but lighter
PLANS: Stage 2+
Offline chungster
Re: S3 Intercoolers
« Reply #8 on: June 23, 2012, 09:45:22 pm »
What's wrong with the Twintercooler setup? Works great on mine I have to say  :happy2:
Offline GarethB
Re: S3 Intercoolers
« Reply #9 on: June 23, 2012, 09:47:10 pm »
X2
Plus it is a doddle to fit  :happy2:
Offline Tamiyoman
  • -Receive: 39
Re: S3 Intercoolers
« Reply #10 on: June 25, 2012, 09:50:28 am »
Jabbaluke's ED30 is running approx 400bhp (Hybrid K04) and using S3 intercooler  :happy2: :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: S3 Intercoolers
« Reply #11 on: June 25, 2012, 09:53:20 am »
Hmmm might just go S3 then... found new metal end tanked ones for £252 this about right? Is this something I could fit myself or best off gett JKM to fit...
Dom
Diesel Daily Hack.
Offline dan930
  • -Receive: 56
Re: S3 Intercoolers
« Reply #12 on: June 25, 2012, 09:56:24 am »
Dom
Where did you find the s3 ic mate, I might be going down this route too
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: S3 Intercoolers
« Reply #13 on: June 25, 2012, 10:01:15 am »
On ebay matey...
Diesel Daily Hack.
Offline DFish
Re: S3 Intercoolers
« Reply #14 on: June 25, 2012, 10:10:16 am »
Not sure if this will be removed, but Darkside Developments have them cheaper. :)
Fish
