Author Topic: Knocking/Tapping Noise  (Read 1909 times)
Offline tartanmartin85
« on: June 24, 2012, 08:04:02 pm »
Hi guys, I've recently developed what seems to be a knocking type noise when turning close to full lock right and accelerating.
Any thoughts what this could be? CV joints? I've also seen this subframe issue with the spacers/bolts from awesomeGTI, is this a potential fix? Cars a 2005 with 50k miles.
Cheers  :happy2:
Offline Black9
  • -Given: 35
Re: Knocking/Tapping Noise
« Reply #1 on: June 25, 2012, 10:38:01 am »
Try the subframe bolt/spacer mod. For under a tenner u can't go wrong. Most likely ur problem.
Offline Sharif
« Reply #2 on: June 25, 2012, 11:06:09 am »
For the noise on near enough full lock, could be your top mounts?
I had the same problem, fitted the ECS subframe spacer and it made no difference, changed the top mounts and the noise went.
Offline -blade-
    • Members Rides
« Reply #3 on: June 25, 2012, 10:53:35 pm »
Always go cheapest potential solution first........ And this one you can't go wrong anyway at 30 mins and the price of a burger  :party:
'05GTI FSI Tornado Red | Leather | 18"BBS | lowered on Coilovers | TorqueTronix @260BHP | ITG intake | Forge DV | SS Downpipe | SS De-cat | Carbon Grille | HID's | Team Heko Deflectors | Ducted Fog Covers |
Offline Black9
  • -Given: 35
« Reply #4 on: June 26, 2012, 02:21:24 pm »
I had my top mounts changed and it never solved the problem ur describing but did stop the creaking. Try the bolts first & if it doesn't cure it most likely top mounts
« Reply #5 on: June 26, 2012, 08:57:02 pm »
Thanks guys!
Just a little update - its actually not as close to full lock as I thought but it's definitely for right turns only and when I am accelerating. Probably more of a loud clicking noise. Anything change with your thoughts on it?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #6 on: June 26, 2012, 10:43:02 pm »
Thanks guys!
Exactly the same as mine!
I replaced my drop links and had my bushes checked. Still doing it  :sad1:
Top mounts next step!
« Reply #7 on: July 03, 2012, 04:03:24 pm »
I had a garage do a test-drive and they are confident that's it's the CV joint that's had it.
They are quoting £130 fitted, that seems quite a bit to me but does that seem reasonable?
Offline TopsGTI
« Reply #8 on: July 03, 2012, 08:42:24 pm »
Think I paid around that price last August at the stealers!
