Author Topic: Do vw head units have pre outs for amps?  (Read 2538 times)
Offline subzero
« on: June 25, 2012, 09:22:05 am »
as above realy, got a standard rcd300 i think it is, got amp and sub from out car but dont noe if this head unit has pre outs, can any1 help?
Offline Dan648v
  • -Given: 28
Re: Do vw head units have pre outs for amps?
« Reply #1 on: June 25, 2012, 09:23:47 am »
I have a rns510 and would like to know this!
Offline Pashka
« Reply #2 on: June 26, 2012, 04:43:25 am »
No, its not. Only mfd2 has preouts with additional cable. You must  use LOC adapters ( like Audiocontrol lc6 or similar ) or amp with high level inputs like Blaupunkt pnp. In any cases, rcd300 is horrible. RNS310,510 are the huge improvement.
« Last Edit: June 26, 2012, 04:49:27 am by Pashka »
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
vw55raz
« Reply #3 on: June 26, 2012, 09:07:44 am »
There are adapters you can buy which can use The speaker outputs as sub phone inputs. I've seen a guy have a sub with his rns 510. Not sure how he gets the remote wire signal to trigger the amp to come on. Unless he has a separate switch for that
Offline Pashka
« Reply #4 on: June 26, 2012, 08:26:28 pm »
Remote can be taken from cig lighter. Some premium loc adapters has remote cable option.
Offline Grande_GTi
  • -Given: 41
« Reply #5 on: June 28, 2012, 10:20:50 am »
Im in a similar situation at the moment too
Ive fitted a RNS510 in to my mk5, Ive been looking into this for a few weeks as the last thing I want to do is blow the new unit up, so the answer is to buy a High level adaptor/convertor which as rightly said above u connect the unit to your speakers, remote wire can be picked from the climate control unit too.
The most important thing to me is that you must buy an AMP that has an adjustable bass/sub level control as the RNS510 does not have them controls.
Hope that helps mate
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
vw55raz
« Reply #6 on: June 28, 2012, 10:28:32 am »
Just to add to that, some amps have a long cable which runs from the amp to the dash area which has a adjustable knob to control the amp gain level. My kicker amp had this. Very useful if you have a boot install where it's hard to access the amp.
Offline CocoPops
    • Kennet Heath
« Reply #7 on: June 29, 2012, 03:51:30 pm »
Or fit the Blaupunkt Plug and Play Amps  :happy2: THA475 for example.
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
