Author Topic: *****Scopes RS GTI*****  (Read 138874 times)
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Scopes Reflex Silver GTI
« Reply #45 on: August 03, 2012, 10:13:23 pm »
Had a bit of painting done...   :innocent:
IMO i think it looks a whole lot better, the way it should have came out of the factory   :drool:
I Left the back centre sction OEM to break it up a bit, same on the front spliter...  :evilgrin:
It could have all been painted, but then it would have needed wrapped or painted gloss black & i think if the front had been painted before long due to stone chips it would have needed painted again sometime very soon!
I would like to get the vortex front spliter in the near future, it i think lowers the front end abit more, without going ed30 look-alike  :innocent:
« Last Edit: August 03, 2012, 11:31:35 pm by scopes »
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #46 on: September 03, 2012, 03:33:46 pm »
Well Bit of an update with a few new bits added!    :laugh:
I got a VCDS Lead just to have a play with and help others out:
I added the Auto-door lock feature when driving off @ 15mph or 15km/h which ever one is correct. I tried to add the fog lights to activate when cornering but it wouldn't allow me i needed a different module at a cost of approx 200 quids  , save that for another day...
I was able to activate my friends, which is a 2008 ed30 & it works great.
I haven't had a chance to run logs but i will soon!  :party:
Silver ashtray lid stuck on, just to see if i liked it, it adds abit of something different to that area, it was only the sticky type one but i have a different idea already to put in its place   :smiley:
Added in the OSIR suede gear stick gator, that wasn't to easy, i had taken it apart & wish i didn't start it so late in the evening,  :signLOL:,  but i accomplished it OK...  I was very careful as i didnt want to be left using the bare gear stick.
I put the gear stick up in to 3rd gear & levered the bottom part out, then the clips that held it in place came undone,
I give the gear stick a bit of a pull & off it came...
Now to take it apart, i removed the ring piece that held the gear knob on, Un-clipped the clips that held the bottom part of the gator to the plastic surround. Now in pieces ..I had to rebuild it with the new gator, a bit of cutting was needed put it together. A few Staples where added in the same place as the original one, i had popped it together and added a bit of sticky tape over the clips just in-case as it was a tight fit ( we all like to hear that ) and put the sliver surround back on & re-fitted back in the car...
The hand brake cover is from an ed30 quite easy to take off & put back on. Nice touch with the red stitching...
Next up was the chrome headlight switch, push, turn, out it came & disconnected the wire, re-connected the new one & pushed it back in easy as!
Drivers door interior handle changed with the chrome window & mirror adjuster switches no need for the door card to be removed for this side...
As for the passenger side door, it needed the door card removed 4 screws 3 along the bottom 1 up the side & 2 bolts in behind the door handle with the trim removal tools pop, pop, pop around where you see the plastic type screws then of with the door-card, disconnected the electrics to the window switch to give a bit more room. Then another 2 screws holding the door handle screwed on the back or was it 3. Old one off, new one on, with the chrome switch.
 Put back together in reverse order!
The old handles were looking abit worn and marked I have to say it freshened up nicely
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #47 on: September 06, 2012, 02:46:02 pm »
A bit of an update !  :laugh:
My summer wheels on:
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #48 on: September 19, 2012, 02:45:04 pm »
Another update!
Got my hands on a new air filter to try it out...  Looks good, sounds good, just need some dyno testing now  :party:
Stright fit on, in place of the Dbilas Filter  :evilgrin:
Then the coolant cover arrived the other day, so attached it lastnight:
 :jumpmove:      :jumpmove:      :jumpmove:      :jumpmove:      :jumpmove:      :jumpmove:      :jumpmove:      :jumpmove:      :jumpmove:      :jumpmove:      :jumpmove:      :jumpmove:
Got these to go on, seems to be a bit of a nightmare to fit these thou!
Had some FAST decals lying about so put them to good use...
 :jumping:
Silver is the way !
Offline smyffalis
« Reply #49 on: September 19, 2012, 03:30:01 pm »
Being a nosey fecker I had a look though the past, actually had your build thread up to read on a tab for a while now haha. Lovely car mate! I wouldn't really be up the northern direction though if I am, I'll keep an eye out!
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #50 on: September 20, 2012, 11:37:05 am »
Hey Smyffalis
Cheers :drinking: for the comment, hope you enjoyed the read through my build thread, that’s what its there for  :jumpmove:...
Yes I will keep an eye out for yourself, do you have the fat five spokes on  :happy2:  or how is your car looking at the moment?
 :popcornsoda:
« Last Edit: March 18, 2014, 10:20:42 am by scopes »
Silver is the way !
Offline N13SCB
« Reply #51 on: September 20, 2012, 02:38:19 pm »
Just read through the build there, very nice car  :happy2:
Where did you get your gator?
Cheers  :happy2:
Slowly progressing. . .
Offline nathangallo
« Reply #52 on: September 20, 2012, 03:05:47 pm »
Added 1 of these... From forge
with #
From Newsouth
We're abouts did you get the dump valve from?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #53 on: September 20, 2012, 03:13:27 pm »
Cheers  :happy2:
 Cheers N13SCB for the compliment, The Gator is from OSIR @ http://www.osirusa.com/
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #54 on: September 20, 2012, 03:15:00 pm »
with #
From Newsouth
Hey Nathan
Direct from Forge  :happy2:
Silver is the way !
Offline nathangallo
« Reply #55 on: September 20, 2012, 03:16:04 pm »
Did you have to buy the adapter or does it bolt on?
Offline Mackie1
  • -Given: 22
« Reply #56 on: September 20, 2012, 03:32:02 pm »
Hey Neil your build thread's coming along nicely  :congrats: I've seen this car in the flesh and i've gotta say that it's one of the nicest Mk5s around (especially since the recent paint job was completed) at the minute. The mods list is truly endless and the attention to detail is superb. respect to you mate   :drinking:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #57 on: September 20, 2012, 03:44:05 pm »
Hey Nathan
Everything needed comes included with the DV  :happy2:  easy to fit on the KO4s or if you had a DV relocation kit... But when fitting to the K03 turbo it is a tight fit in there...
Hope that helps!
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #58 on: September 20, 2012, 03:52:51 pm »
Appreciate That Stevie Mac,  :happy2:  Yours to myman! I can’t believe how far it has come along... I'm just wondering will it ever stop or will there always be room for improvements...  :fighting2:
Also with a new set of wheels on there way, I can't wait to see how she looks then  :jumping: :jumping: :jumping:
I feel like a kid at Christmas  :grin:
« Last Edit: September 20, 2012, 08:13:58 pm by scopes »
Silver is the way !
Offline Aaroncupra
« Reply #59 on: September 20, 2012, 10:20:25 pm »
Well Neil,
Nice car mate  :happy2:,
Best colour  :smiley:
