Author Topic: Changing the Vw head unit to an aftermarket unit  (Read 2636 times)
Offline Toast
« on: May 25, 2009, 07:16:08 pm »
Hey guys looking for some info on the above as I currently have the six disc vw unit in the ed30 and have saw a nice alpine double din screen! 8)  My questions are would the new unit basically be a plug in and play method obviously a new fascia will be needed but do I need a canbus adapter or such like?! :confused:  And I'm also thinking of putting a sub and amp package in the boot along with uprating the speakers :wink:
Any info on these would be great  :happy2:
Offline SteveS
Re: Changing the Vw head unit to an aftermarket unit
« Reply #1 on: May 25, 2009, 07:17:59 pm »
yes u need an ISO adaptor for the car, for external amps/sub u need outputs from ur headunit which u should get with that one
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
« Reply #2 on: May 25, 2009, 07:25:17 pm »
Do it and your VW dealer may not want to use their machine to scan your car for fault codes...   :sad:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #3 on: May 25, 2009, 07:28:16 pm »
It you want plug and play then a CAN BUS iso adapter is needed, this will supply the switched 12v+ and lights on/dimmer signal/wires that aren't present on the standard loom.
Other wise you will need to run at least the 12v+ switched from one of the spare points in the fuse box.
The difference is about £50 for the CAN BUS ISO adapter or a £10 for the standard adapter.  :happy2:
PS - I will move this to the Car Audio section  :smiley:
Offline Toast
« Reply #4 on: May 25, 2009, 07:37:58 pm »
Been on Car Audio Security.com there and found this
http://caraudiosecurity.com/shop/product_list/c_path/48_670_684/spd/vw-can-bus-adaptors.html
Is this what I need? :confused:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: May 25, 2009, 07:51:39 pm »
^^ Yep that's the exact one you need for a Plug and Play install  :happy2:
It's also the one I have used previously and can recommend.
Offline Toast
« Reply #6 on: May 25, 2009, 07:53:49 pm »
Cool cool  :happy2:  I'll see about sorting me sounds out once the car is back from the paint shop :jumpmove:
Offline Alexander
« Reply #7 on: May 26, 2009, 10:52:49 pm »
i used the standard adapter and ran a switched live from the fuse box took about 15 mins to do!only thing it doesnt have is a dimming when the lights are on feature which the canbus adapter will provide.
If you choose uprated speakers make sure the mids arnt too deep as there isnt much depth there.
Sub wise I can recommend the vibe active subs which take the hassle out of choosing an amp and save space. I have a 10" whic sounds awesome and you can plug the port for tighter sounds.
pics here http://www.mk5golfgti.co.uk/forum/index.php?topic=4670.0
2005 Black Audi A3 Sportback TDI-Bose and Full Leather
2005 Black 3Dr GTI-Leather and Upgraded Sound System-Gone
Offline Toast
« Reply #8 on: May 27, 2009, 07:26:10 pm »
Cool thanks for the info buddy :happy2:  Had a look at your sub looks good I used to have the twin 12" vibe cbr's in my mk4 golf  along with infinity's all round Very Very LOUD  :jumpmove: :rolleye:
