Author Topic: High octane vs regular  (Read 977 times)
Offline martziniuk
« on: June 27, 2012, 07:13:39 pm »
How much does running 95 Ron against 99 Ron at stage 2+ effect your timing pull? Logs or numbers from VCDS would be great  :happy2:
Obviously I don't run 95 but in an emergency I put 1/4 of a tank in to last.
Offline PDT
  • -Receive: 142
Re: High octane vs regular
« Reply #1 on: June 27, 2012, 07:37:28 pm »
Depends on car and map settings. Typically I can tell what fuel a TFSi has in based on the logs.
Offline martziniuk
« Reply #2 on: June 27, 2012, 08:08:55 pm »
So what would you say was a typical difference, -4 between the two fuels?
« Reply #3 on: June 27, 2012, 10:11:17 pm »
iirc one guy posted up some logs with 95 octane with a little too much CFs. Was advised to use V-Power and it made quite a difference to the amount of CFs he was getting.
Unfortunately I can't recall the member's name...   :ashamed:
