Author Topic: Engine Warning Light - problem found and help needed  (Read 12187 times)
Offline johnhol78
« on: June 27, 2012, 09:07:50 pm »
Had the warning liht com up on my way home. No side effects I could tell or notice. Car slightly lumpy on idle though only very slight.
Anybody no the possible cause of this error:
1 Fault Found:
004195 - Fuel Pressure Regulation: Control Range Not Reached
               P1063 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100010
                    Fault Priority: 0
                    Fault Frequency: 8
                    Mileage: 128030 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:21:02
             Freeze Frame:
                    RPM: 759 /min
                    Load: 17.2 %
                    Speed: 8.0 km/h
                    Temperature: 87.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
« Last Edit: July 07, 2012, 08:19:57 pm by johnhol78 »
Offline johnhol78
Re: Engine Warning Light - advice
« Reply #1 on: July 01, 2012, 10:59:15 pm »
Anyone?
Hasn't happened since though would like an idea :)
Worried the fuel pump is on it's way, Have autotech internals as well
« Reply #2 on: July 01, 2012, 11:03:48 pm »
Ever changed your cam follower?
Offline edd666999
  • -Receive: 89
« Reply #3 on: July 01, 2012, 11:04:44 pm »
Offline johnhol78
« Reply #4 on: July 01, 2012, 11:06:41 pm »
Logged this - Fuel pressure is well off. Could the Fuel filter cause this or is it definitely the pump?
Offline johnhol78
« Reply #5 on: July 01, 2012, 11:07:00 pm »
Yep when the internals were put in.
Offline edd666999
  • -Receive: 89
« Reply #6 on: July 02, 2012, 12:06:47 am »
link i sent said pressure sensor or follower, both cheap fixes so id start there!
Offline johnhol78
« Reply #7 on: July 02, 2012, 07:28:10 am »
Sorry Ed didn't see your post.
Will order a cam follower today - is the sensor just called Fuel Pressure sensor? Part num?
John
« Reply #8 on: July 02, 2012, 10:32:47 am »
etka calls it Thrust Sensor and the latest part number is 06E906051K.   :smiley:
Offline johnhol78
« Reply #9 on: July 02, 2012, 01:31:26 pm »
DIY job or garage only?
« Reply #10 on: July 02, 2012, 01:59:56 pm »
It's easily a DIY job with the correct size spanner.
I suggest first you relieve the pressure in the fuel rail by bleeding it using the Schrader bleed valve on the hpfp.
Offline johnhol78
« Reply #11 on: July 02, 2012, 06:47:25 pm »
Awesome thanks....will try this first. Then if no improvement tackle the nightmare of taking the fuel pump off (banjo fitting) and checking the cam follower.
« Reply #12 on: July 02, 2012, 08:16:49 pm »
You should be aware that the sensor is around £48 from the dealers so IMO you should look at the cam follower and cam first to minimise unnecessary spending.
Offline johnhol78
« Reply #13 on: July 02, 2012, 08:51:42 pm »
Sorry for the questions....but what does checking the cam entail? Cam follower I'm fine with though the cam?? not so sure.
« Reply #14 on: July 02, 2012, 11:20:53 pm »
Just run your fingernail on the cam lobe surface after you remove the follower.
If the follower is in good condition it should be smooth. If the follower is very worn down but not punched through then it's worth checking the cam for smoothness as a heavy scratched lobe can cause increased wear on the cam follower.
