Author Topic: Engine Warning Light - problem found and help needed  (Read 12186 times)
Re: Engine Warning Light - problem found and help needed
« Reply #30 on: July 27, 2012, 09:41:17 pm »
A worn down A revision cam should feel smooth but the lobe height would be reduced leading to the discrepency between requested and actual rail pressure.
Offline johnhol78
« Reply #31 on: July 28, 2012, 07:36:33 pm »
Logs redone and this time with block 103.
Car was fine this time. No major power loss.
https://docs.google.com/file/d/0B9iyWw-ZADAfc3hlWEpIeGJ2c1U/edit
nightmare when it's intermittent
Offline johnhol78
« Reply #32 on: August 01, 2012, 05:49:39 pm »
Well bought new thrust sensor and was fitting it when I noticed the bajlnjo joint was wet. Looks like I did tighten properly when I changed the cam follower. Slightly embarrassed. Just hope that was the issue.
« Reply #33 on: August 01, 2012, 06:01:31 pm »
Don't overtighten it!
If it's still leaking after tightening then I suggest you replace both the brass hpfp fitting and bolt.
Offline johnhol78
« Reply #34 on: August 01, 2012, 08:46:26 pm »
Seemed ok, car was very responsive though EML came back on. Haven't checked code yet. Will do in a bit.
Seriously considering selling up and getting an ST. Nothing but issues.
