Author Topic: New Member  (Read 1518 times)
chez
New Member
« on: June 28, 2012, 10:35:09 pm »
Hi All. I'm Matt. Thinking of going to look at this gti at the weekend. http://www.philippaul.co.uk/used-cars/volkswagen-golf-2-0t-gti-3dr-oswestry-201220471476527
I have a had a quick look around it and I see the rear badge has faded / white colouring problem and also the one skirt looks like it's been caught maybe. Is there any other issues should I look out for? What recalls are there? Does the price seem a bit high? Does tornado red fade? Thanks
Offline Moz
Re: New Member
« Reply #1 on: June 28, 2012, 10:38:03 pm »
8.5 is high I'd say.
Offline Rachael
Re: New Member
« Reply #2 on: June 30, 2012, 09:37:04 pm »
Hi matt. Welcome. I rang about that car aswell. Part service history put me off slightly. And yer 8.5 is bit steep if you compare on auto trader :). Good luck though!
Saintsteve
Re: New Member
« Reply #3 on: June 30, 2012, 09:38:18 pm »
welcome!!! Great choice fella  :happy2:?. the tornado red so far on the mk5 doesn't seem to have fading issues. maybe it's the type of paint that's now used on the newer cars etc..
« Last Edit: June 30, 2012, 09:44:28 pm by Saintsteve »
chez
Re: New Member
« Reply #4 on: June 30, 2012, 09:41:22 pm »
Went to have a look today. Was quite disapointed with it. had bolster wear on the seats, rear badge was the white sort of laquar peel on it on the bottom of the badge, various scratches on it. Decided it wasn't the one for me in the end needed a fair bit of little bits to tidy it up and 8.5k is a bit steep. Went to look at a scooby which is a possiblity maybe. Still fancey a gti maybe, case of finding one that ticks all the boxes.
Re: New Member
« Reply #5 on: June 30, 2012, 09:56:00 pm »
welcome to the forum--keep looking as there is plenty out there to choice from,
  • -Receive: 427
Re: New Member
« Reply #6 on: July 01, 2012, 11:18:22 pm »
Welcome along!   :drinking:
You can get a better one than that fella!!
Good luck with your search, always enjoy car hunting myself.
Offline Kalpsn2000
  • -Receive: 56
Re: New Member
« Reply #7 on: July 02, 2012, 01:03:02 pm »
That is probably 'white worm'. You will find this on the earlier cars which have the flat 1 piece badges (changed to the new design in 2006 I think). Also affects the diamond cut 18" Monza II's and wheel centre caps.
This is the worst case I have seen:
http://uk-mkivs.net/forums/t/307205.aspx
Offline DannyO8Gti
Re: New Member
« Reply #8 on: July 02, 2012, 03:04:39 pm »
Welcome  :smiley:
Offline matt404
Re: New Member
« Reply #9 on: July 03, 2012, 12:34:43 pm »
Welcome! Keep looking and eventually you will find the right one.  Took me nearly 3 months and several wasted trips where people had advertised them as immaculate (Should have gone to specsavers) but it will be worth it when you do find a gem!
