Author Topic: Apple VPN Help  (Read 994 times)
Offline prepree
Apple VPN Help
« on: June 29, 2012, 11:55:56 am »
HELP!!
Im trying to set up a VPN on my macbook, I go to network - create a new VPN, enter the server address, hit connect and it prompts me -
The IPSec Shared Secret is missing?
What is a shared secret???
Offline Betty02
    • iBett
Re: Apple VPN Help
« Reply #1 on: June 29, 2012, 01:35:45 pm »
Do you have any hidden shares on the server? You will know this as they will probably end with the $ sign? say for example its http://10.201.86.121/homefolders/users/2012/simon$ that will make the folder a hidden share? Might be worth checking the server! is it a windows server your connecting too?
More info and I should be able to help :)
ADMIN NOTICE: Please do not use the site for advertising!
Offline prepree
Re: Apple VPN Help
« Reply #2 on: June 29, 2012, 01:38:59 pm »
Never seen any $ signs betty, yes it is a windows server.
Im trying to VPN to my desktop at work if that helps, sorry not very technical!!
Offline richtung
  • -Receive: 56
Re: Apple VPN Help
« Reply #3 on: June 29, 2012, 01:55:23 pm »
if you start with the basics.... is the server address correct? is this what your IT department have supplied you with?
(dont post it on here)
Rich
Offline prepree
Re: Apple VPN Help
« Reply #4 on: June 29, 2012, 01:56:17 pm »
Hey rich, yes first thing i checked when it didnt work
Offline richtung
  • -Receive: 56
Re: Apple VPN Help
« Reply #5 on: June 29, 2012, 01:59:51 pm »
is it in numbers (an IP address) or in words (like your.works-vpn-server.co.uk)?
Offline prepree
Re: Apple VPN Help
« Reply #6 on: June 29, 2012, 02:06:30 pm »
Numbers, with dots in between
Offline richtung
  • -Receive: 56
Re: Apple VPN Help
« Reply #7 on: June 29, 2012, 02:10:23 pm »
ok, so you have the IP address.
would you be able to ask your IT department if they have the full domain name-  it will be in words..
Offline prepree
Re: Apple VPN Help
« Reply #8 on: June 29, 2012, 02:21:16 pm »
Will do now Rich
Another thing that might assist you is we use  PPTP connections, i was using L2TP over IPsec, now when i use PPTP I enter the server address, enter my account name - in authentication settings enter my workstation password. OK - then connect and now i just get Authentication Failed
Offline richtung
  • -Receive: 56
Re: Apple VPN Help
« Reply #9 on: June 29, 2012, 02:26:29 pm »
im not all too familiar with your company setup.
At mine, from home for example, on a windows machine, you would establish the VPN first to work network and then establish a remote desktop connction to your work station at work... seems like its a bit different to yours..
