Author Topic: RCD300 & RNS510 swap  (Read 1401 times)
Offline mad_pete
« on: June 30, 2012, 09:24:07 am »
I'm looking to swap a RNS510 and RCD300 between 2 08 plate cars.
Do I need the adaptor for the aerial and a new gps aerial?
Or is it possible to get the factory fit gps aerial out? Do I need an adaptor to allow the rcd 300 to go where the rns510 was ?
Offline mad_pete
Re: RCD300 & RNS510 swap
« Reply #1 on: July 03, 2012, 04:31:25 pm »
The gps aerial and convert to the 510 seems straightforward putting the rcd300 where the 510 was seems like it might need an adaptor made. Are they standard connecters ? Maybe I can get some and make a cable.
Offline DaveR77
    • UK-MKIVS.net
« Reply #2 on: July 03, 2012, 06:51:29 pm »
You'll need an aerial adapter for the car with the RCD, unless the other car has one
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180915455858#ht_500wt_1413
No
« Last Edit: July 03, 2012, 06:55:47 pm by DaveR77 »
Offline mad_pete
« Reply #3 on: July 03, 2012, 07:13:53 pm »
Thanks but I also need the opposite of that to fit a Rcd300 into a rns510 connector.
