Author Topic: drop in power until 3000rpm, FINALLY FIXED BY STATLLERS!!!!  (Read 22926 times)
Offline robdf2
Re: drop in power until 3000rpm, any ideas?
« Reply #30 on: July 11, 2012, 05:24:16 am »
Thanks for the suggestion. Is it the n205 valve?
Was this what was wrong with yours Rob?
Hey Dom
The problem with my car was that the dealer just set my cams wrong but the dealer and seat swore there was nothing wrong
Since then they have said that because it's a variable timed engine it don't make any difference lol.
The part I'm talking about is actually part of the variator the big aluminium bit on the right hand side of your engine, this houses the chain that drives your cam shafts and in there is a spring and pin mechanism which is suppossed to lock in place on choke , but the springs can become weak or broken.
It's just another thing to rule out mate.
Didnt someone also have a broken cam shaft sprocket which have similar issues to what you are experiencing?
Keep your chin up buddy I went through sh*t for 3 1/2 years to find my issue.
2008 Chrono yellow Cupra
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #31 on: July 11, 2012, 04:24:12 pm »
Haha that's reassuring to know lol   :sick:
But a good few things to check there Dom... hope they help.
Diesel Daily Hack.
Offline heavyd
  • -Receive: 29
« Reply #32 on: July 11, 2012, 07:40:19 pm »
It going in to get sorted on Saturday. Hope it isnt the variator, over £300 just for that little bit of aluminium  :surprised:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #33 on: July 11, 2012, 10:41:11 pm »
Fingers crossed for you bud...
Diesel Daily Hack.
Offline robdf2
« Reply #34 on: July 13, 2012, 06:36:31 am »
Hope you get it sorted mate , and it puts the smile back on your face :-)
Nothing worse than trying to find a bloody fault with no fault codes , I'm sure it will be something simple,
Keep us updated mate
Offline robdf2
« Reply #35 on: July 18, 2012, 05:06:04 am »
Any updates mate?
Offline heavyd
  • -Receive: 29
« Reply #36 on: July 18, 2012, 05:55:12 am »
Statllers have got the car, theyre going to try and  fit it in when they get the time, so no updates as of yet :popcornsoda:
« Reply #37 on: July 18, 2012, 12:25:22 pm »
its in goods hands then  :happy2:
Offline robdf2
« Reply #38 on: July 26, 2012, 11:20:24 am »
Any more updates Dom?
Offline heavyd
  • -Receive: 29
« Reply #39 on: July 26, 2012, 01:00:52 pm »
Still haven't heard anything yet mate :popcornsoda:
Offline robdf2
« Reply #40 on: July 29, 2012, 11:46:40 am »
What have they found so far?
Offline heavyd
  • -Receive: 29
« Reply #41 on: July 29, 2012, 01:16:52 pm »
Got nice valve marks on the pistons, new rocker rollers in and cylinders still leaking :scared:
Don't know if it's from when the cams were put in wrong and caused damage that has got worse, badly reassembled cylinder head refurb or something else. Statllers has assured me they will sort it out for me :notworthy:
Offline robdf2
« Reply #42 on: July 29, 2012, 06:20:57 pm »
Have you informed the bunch of muppets who did the work?
That's shocking !
Feel for you buddy
When you say pistons still leaking you talking about a leak down test?
Offline Marshall
« Reply #43 on: July 29, 2012, 09:40:25 pm »
Looking a that you'd think a key way on a cam or crank gear had worn or broke causing the timing to dance around causing contact.
Saying that to make contact your talking more than 1 tooth out so hope it's not done too much damage and you get it sorted once and for all.
Do you think that last time you got it sorted that was just the effect that was fixed and the original cause has always been there?
MISANO RED RS3
Offline PDT
  • -Receive: 142
« Reply #44 on: July 30, 2012, 10:06:42 am »
Dom, you should gather all evidence of the faults that have been caused due to this engine rebuild and present them to the place that carried out the work, their mistakes must have cost you a small fortune by now.
