Author Topic: Autotech HFPF issues or not?  (Read 1892 times)
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« on: July 01, 2012, 09:27:59 pm »
I have an AXX in for custom mapping with k04 and S3 injectors,  I am mapping it to around 300lbft 320bhp with 130bar rail pressure via the Autotech internals, the car is fine for the first 5 mins driving / 3-4 dynos runs making 130-135bar on demand, but then the actual pressure starts the drops of the 130bar request by around 30bar across the whole range and is very slow to even build up to 90-100bhp.    I have changed the cam lobe and fuel pump and still getting same issues.
Has any had or read of this issues before?
01455 617233
Offline vRSAlex
  • -Receive: 253
Re: Autotech HFPF issues or not?
« Reply #1 on: July 01, 2012, 09:55:15 pm »
Was there much wear on the old follower?  I had a bwa in the other day with the early 'A' inlet cam and it had worn the lobes right down.  Was it the follower or lobe you changed?
How are the lpfp pressures looking?
Is it running an rs4 fprv?
Follow AKS tuning on Facebook
Offline R-tech-Nick
  • -Receive: 30
« Reply #2 on: July 01, 2012, 10:15:29 pm »
Cheers for reply  :happy2:
We changed the cam follower, there was bad wear on the old one with some metal pick up on it.
Yes there is an RS4 valve on it as
The low pressure side (from memory) is around 4650mb @ 6300rpm with 108bar actual rail pressure with 130 requested
01455 617233
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: July 01, 2012, 10:20:23 pm »
Pop the new follower out and see if its worn already.  This would tell me the cam is fooked.  Take off the side casing and see if the cam is the a or b cam.  If its the 'a' then its a one piece cam and lobe.  Get it changed out for the revision b as 130 bar will kill it, or it already may have done that.
Offline R-tech-Nick
  • -Receive: 30
« Reply #4 on: July 01, 2012, 10:38:47 pm »
Cheers for the help Alex.. :happy2:  I will text Kenny (the owner) and tell him to do the checks and let me know.  I will report back soon.
Nick
01455 617233
