Author Topic: OBD Port security vulnerbility..  (Read 8685 times)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: OBD Port security vulnerbility..
« Reply #15 on: July 04, 2012, 06:05:20 am »
I have a VW and I have VCDS which uses the diagnostic port. To use VCDS I have to put this thing called a key in a hole and turn it first. Wonder why BMW didn't think of that?
There is a similar tool that will start the car for vag group vehicles to bypass the immobiliser, you don't need the ignition on for that.
And there are limited number of keyblades variations, a well equiped thief will have all of them
Cluster and Key coding
Location Great Yarmouth
« Reply #16 on: July 04, 2012, 08:31:12 am »
Yes the OBD port is live even without the ignition on as you initially plug the Bluefin handset in with the ignition off.
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #17 on: July 04, 2012, 08:51:08 am »
Best security measures to take, to help prevent this happening?
A friend relocated his obd port to another position in the car but left the original there with a permanent 12v on the pins to fry any device that is plugged into it :laugh:
Hide your OBD port. Sometimes we get a car in for tuning where the OBD port has come loose and means you cant plug into it, can take ages removing trim to find it again.
This sounds like the best solution for those concerned. Only thing I can think of is you might get a few angry garages coming after you if you fry their diagnostic/servicing tools if you forget to tell them about the 12v live.  :nerd: :jumping:
Offline simonp
  • -Receive: 38
  • No longer a Golfer
« Reply #18 on: July 04, 2012, 11:22:49 am »
Well I for one am happy that this tech exists. I'd rather some twocker comes to my house equipped with a laptop than kicks the door in and demands the keys at knifepoint...
Offline cooljimy84
    • Personal
« Reply #19 on: December 10, 2014, 12:29:03 pm »
?? Shouldn't this be a sticky ??
i knew a few cars were open to it, but the list is growing !
There is no replacement for displacement....
But a turbo does help....
Offline Matthewsimone
  • -Receive: 39
« Reply #20 on: December 10, 2014, 12:40:19 pm »
Have to agree there mateits a lump of metal, i have insurance so if the scum bags want it let them take it
Much prefer that than someone trying to come into my home for keys with my daughter asleep in bed as that could end very messy for me or them  :sick:
Offline omeydz
  • -Receive: 50
« Reply #21 on: December 10, 2014, 01:32:49 pm »
I saw this a while ago. My idea was to chop the obd port and wires off, pin into different type of connector and add the obd to the other end. So male and female connector combo allows you to connect the obd when you want to use it. And when you remove it the thief will be greeted with a different connector and be stumped in theory and not know pin assignments.
Good idea?
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline doylebros
« Reply #22 on: December 10, 2014, 02:30:43 pm »
Best tell James Bond about that idea!
http://rt.com/uk/212795-bond-spectre-cars-stolen/
Offline th3_f15t
  • -Receive: 183
« Reply #23 on: December 10, 2014, 06:01:58 pm »
Plus only a small bit of window smashed compared to trim being ripped off, wires destroyed and locks damaged to achieve the same result. I plan to fit a tracker to my car so even if it does get stolen, least I can inform the police where it is and let them do the dirty work.
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #24 on: December 10, 2014, 06:17:22 pm »
Unfortunately trackers can be defeated very simply and quickly too! If they want your motor it is going regardless, there is so much tech about these days to defeat security measures sometimes a hidden kill switch or similar is more effective. Just type 12v car tracker blocker into your favourite search engine!
Offline doylebros
« Reply #25 on: December 10, 2014, 06:28:45 pm »
Offline Trekmeister
  • Golf GT 140
« Reply #26 on: December 10, 2014, 06:36:53 pm »
Back in the day I had a fiesta XR2 which some determined thieves tried to steal (pushed it away and had a big battery hooked up) but I had a kill switch and therefore they couldnt get it started and ended up leaving it. How hard would it be for an automotive electrician to fit one and would it even work or cause havoc with the ecu given cars have moved on significantly over the past 20 years?
Offline W6llace
« Reply #27 on: December 10, 2014, 06:47:40 pm »
Gonna wire my gti to the mains that should do the trick  :P
