Author Topic: New pipercross/revo intake for the mk6 *TSI intercooler talk*  (Read 4555 times)
Offline cal tdi
  • dub or die
Re: New pipercross/revo intake for the mk6
« Reply #15 on: July 24, 2012, 01:48:47 pm »
It's certainly a different/better spec than the older tfsi item then. If not a match to the s3
Candy weiß Mk6 GTI - Stage 2
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #16 on: July 24, 2012, 02:45:38 pm »
I swapped the cooler for S3 on both my TFSi and TSi and they are pretty much the same intercooler from what I could see. Certainly same thickness (or very similar) cores.
The S3 is thicker by some margin. 20mm springs to mind but I would have to measure it.
Offline jon-tfsi
  • -Receive: 27
« Reply #17 on: July 25, 2012, 09:51:26 pm »
The Mk6 GTI has the same IC as later spec S3's
Having swapped mine for an S3 cooler I can tell you it's not.
The UK Mk6 Golf GTI has the same IC as the GOLF R and later spec S3.
In other continents it does not.
GOLF R Mk7
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #18 on: July 25, 2012, 10:02:09 pm »
My 2011 vRS, which has the same engine, had a different cooler :confused:
Offline jon-tfsi
  • -Receive: 27
« Reply #19 on: July 25, 2012, 10:08:23 pm »
Maybe this is why the Golf is £4K more ?? :signLOL:
Just done a quick google search and its deffo not on the US spec MK6. I wish i knew how to add a link as i have found a great quote by "Bruce" stating the s3 cooler with plastic end tanks is actually more efficient than the alloy one !!
GOLF R Mk7
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #20 on: July 25, 2012, 10:26:18 pm »
Cheeky fecker, they have the same cooler  :P
Don't start that debate again ffs  :rolleye:
Offline jon-tfsi
  • -Receive: 27
« Reply #21 on: July 25, 2012, 10:31:34 pm »
  :signLOL:Just to add fuel to the fire this is a copy and paste of Bruce's post on a US forum:
The Mk.VI Golf R FMIC with plastic endtanks is even more efficient than the old full alloy S3 FMIC.
Hard to believe but true. I was told by a mate working at Volkswagen in Wolfsburg where they did all
the testings. It's not only material and dimensions. The newer one has a better internal shape.
Quote:
Originally Posted by TSiUG
what? i swear they are identical....
Current Golf R, S3 and Mk.VI GTI are identical. The former Mk.V GTI FMIC was thinner and less efficient.
GOLF R Mk7
Offline cal tdi
  • dub or die
Re: New pipercross/revo intake for the mk6 *TSI intercooler talk*
« Reply #22 on: July 26, 2012, 09:41:00 am »
Awesome!!
Nice to know. Probably goes someway to explaining why stage 2 on a ko3 TSI is rather impressive. Mine dyno'd on Monday at over 300
