Author Topic: Oh no!!  (Read 2776 times)
Offline andygo
Oh no!!
« on: July 03, 2012, 03:48:32 pm »
Started to do an oil change on my ED30.
Easy peasy, its first oil change since I bought the car.
Nope.
The rock ape at the previous owners dealers has tightened the plastic oil filter housing up so tight that when I attempted to undo it, it cracked the  36mm hex portion of the housing off. Apart from the pain of £42 for a new housing, whats the best way of getting the old one off. I've tried an oil filter strap, and I cant loosen it even with a 1/2 drive socket set. I've a couple of bust ribs, so I cant give it max attack, but even so...
Is the threaded part of the adapter it screws into ally or plastic. If its ally, I might try to heat the plastic up, but I forsee a world of hassle looming.....
Re: Oh no!!
« Reply #1 on: July 03, 2012, 03:50:38 pm »
Are you turning it the correct way ? Known loads of people to turn things the wrong way and brake stuff like that
Offline andygo
Re: Oh no!!
« Reply #2 on: July 03, 2012, 04:22:44 pm »
No, its deffo the correct way, but thanks for asking..
The one on my previous GTi was almost as tight, but did come off eventually. They are only meant to be done up lightly.
Offline PDT
  • -Receive: 142
Re: Oh no!!
« Reply #3 on: July 03, 2012, 05:18:51 pm »
I have had this when removing the filter when engine is cold, seal off the broken bit and run the engine up to temp at idle and the residual heat may help a bit.
Offline andygo
Re: Oh no!!
« Reply #4 on: July 03, 2012, 05:35:31 pm »
Luckily the housing is intact, its just the plastic hexagonal part of the 'can' that's broken in half so the socket won't work. I will try heating it with a heat gun. Don't want to refill the engine with dirty oil - I've drained it all off.
Concerned that the threaded part of the housing screws onto more plastic rather than metal though. Just in case I have to get a little violent and saw it off. :)
Saintsteve
Re: Oh no!!
« Reply #5 on: July 03, 2012, 05:35:36 pm »
So which way are you trying to turn it, clockwise or anti clockwise?  From under the car? Then at least you know, we know your doing it correct :happy2:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Oh no!!
« Reply #6 on: July 03, 2012, 05:52:59 pm »
Hammer a screwdriver through the housing and use it as a lever. Drill through it if necessary to get the screwdriver or bar or whatever through.
A mate of mine did this, although it wasn't a Golf.
'07 Red manual
Offline andygo
Re: Oh no!!
« Reply #7 on: July 03, 2012, 06:04:55 pm »
I was deffo undoing it. Trust me, lol.
Puncturing it wont work, its a plastic filter housing.
Offline PDT
  • -Receive: 142
Re: Oh no!!
« Reply #8 on: July 03, 2012, 06:36:27 pm »
Dont drill or puncture it! This will fill the filter housing with bits of pastic.
Offline andygo
Re: Oh no!!
« Reply #9 on: July 03, 2012, 07:00:46 pm »
I'm not going to drill it, but I will have a new one to fit, so no real issue there anyway.
Can't believe the wretched thing is on so tight though!
Offline martziniuk
Re: Oh no!!
« Reply #10 on: July 03, 2012, 07:03:22 pm »
Urghh I did this on my first oil change  :scared: I can't remember how I got it off in the end but it was a real headache and I think it involved a hacksaw. A proper oil filter housing socket is essential.
Offline biffobear
Re: Oh no!!
« Reply #11 on: July 03, 2012, 07:11:40 pm »
where did you get a housing for £42 ? i went to a local seat dealer to price one in case i damage mine next filter change and was quoted £100!!!!
Offline andygo
Re: Oh no!!
« Reply #12 on: July 03, 2012, 08:11:31 pm »
Same price quoted by 2 dealers. Part no:06D 115 408B.
£42 is a total rip though..
I bought my this (dont ask!) for £49.
http://www.mothercare.com/Grow-and-Go-Trike/407397,default,pd.html?cm_sp=ProductFeatures-_-Category%2520landing-_-Grow%2520and%2520Go%2520Trike&q=smart%20trike&q=smart%20trike
It wasn't for me, but I had to assemble it. All good quality plastic, proper instructions, well put together, worked perfectly, came in a huge box.
So how come £42 for a crappy oil filter housing..?
VW, you are having a laugh at my expense. I bet it cost you a couple of quid tops.
You make Apple look like charity workers.  :)
Offline rosco07
Re: Oh no!!
« Reply #13 on: July 03, 2012, 08:20:54 pm »
Quality bit of kit that :happy2:  The only issue I have had is the yellow disc in the front wheel working loose at high speeds as it just presses on  :driver:
Offline andygo
Re: Oh no!!
« Reply #14 on: July 03, 2012, 08:39:18 pm »
Nice to get a good track test review!
