Author Topic: BBS LM Reps & NQBBK  (Read 4748 times)
Offline Syrag64
Re: BBS LM Reps & NQBBK
« Reply #15 on: July 05, 2012, 08:28:42 pm »
Cheers everyone  :happy2: :happy2: as usual excellent advice & information  :drinking:
Where is the best place to get hubcentric spacers?  :smiley:
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline Dan648v
  • -Given: 28
« Reply #16 on: July 05, 2012, 09:12:41 pm »
I've been looking at venom Motorsport and eBay so far. Defo go for hubcentric spacers I would say
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #17 on: July 06, 2012, 07:22:30 am »
My personal choice is H&R hubcentric spacers but you may go with others also...
Offline jimk04
« Reply #18 on: July 07, 2012, 11:45:03 pm »
Don't forget longer bolts :happy2:
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #19 on: July 08, 2012, 09:34:49 am »
I would like to point out to the OP that as counter intuitive as it sounds, going from an ET35 wheel to an ET45 wheel will make the problem worse
PLANS: Stage 2+
Offline Syrag64
« Reply #20 on: July 08, 2012, 05:43:03 pm »
can you explain please?  :surprised:
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #21 on: July 08, 2012, 07:11:38 pm »
Well, ET 45 means that the spokes on this rim are 10mm closer to the caliper than the ET 35 rim (taking into account that the spoke design is identical).
So, bad news for you...  :sad1:
Offline Syrag64
« Reply #22 on: July 08, 2012, 09:30:22 pm »
I'm sticking a 10mm space on so should clear calipers hopefully, so really i should of gone for et35? I'm well confused now  :confused:
Offline Dan648v
  • -Given: 28
« Reply #23 on: July 08, 2012, 11:13:31 pm »
Dude you really need to find out wat ET these wheels are that you've got, it's gonna be hard to figure out wat spacer you need till you know wat your working with!
