Author Topic: Seized caliper...  (Read 2812 times)
Offline GTi E30
Seized caliper...
« on: July 04, 2012, 11:53:51 am »
Hi guys...
I had a seized r/o/s caliper which I replaced two weeks ago...
But a week later my f/n/s caliper seized...
This front caliper seizes and Un seizes when it feels like it...it's ok for a few days then it's seized then ok etc...
Any ideas what could be the fault here... ???
Offline Scott_GT_TDI
Re: Seized caliper...
« Reply #1 on: July 04, 2012, 04:35:28 pm »
I had this on my 172 cup once, turned out that although the caliper was seizing, it was a slightly warped disc getting hot and in turn transferring the heat to the caliper which expanded and seized, that was causing the issue. Ordered up some caliper seals and a new piston along with new discs and pads and its still going in the hands of my friend to this day :)
Is it just after a drive that its seizing?
Offline GTi E30
« Reply #2 on: July 04, 2012, 04:49:23 pm »
It seizing when ever it feels like ur really some times it's ok for days but since the last two days it's been seized...
Someone said the brake master cylinder is Nackered ...??? Could that be the problem...???
« Reply #3 on: July 04, 2012, 05:16:48 pm »
A faulty brake master cylinder wouldnt make just one caliper seize I would have thought. Only issue with a master cylinder I've ever had has been a leaking one, with the pedal slowly going to the floor. Sounds quite strange
Offline GTi E30
« Reply #4 on: July 04, 2012, 05:32:56 pm »
My pedal did go to the ground a few times but it's ok now
Offline ashley
« Reply #5 on: July 04, 2012, 06:04:17 pm »
sounds like air in the system following the caliper replacement.
Offline GTi E30
« Reply #6 on: July 04, 2012, 06:10:24 pm »
Could be air... Don't know what to do who ever I talk to they advise something different  :confused:
« Last Edit: July 04, 2012, 06:12:26 pm by GTi E30 »
