Author Topic: Brake Ducts  (Read 4274 times)
Offline lswed30
Brake Ducts
« on: November 19, 2008, 04:41:29 pm »
Me again
When I was poking around the Ed at the weekend I noticed that there are two rectangle holes in the inner arches. I presume this is for brake ducts? Does the R32 run brake ducts? anyone know the part number?
Offline joesgti
  • Eat my sick, Eat my sick.
Re: Brake Ducts
« Reply #1 on: November 20, 2008, 03:25:21 am »
Me again
not sure on this but im sure neilM has fitted aftermarket ones for the track  :smiley:
Offline NeilM
Re: Brake Ducts
« Reply #2 on: November 20, 2008, 10:39:07 am »
After replacing a new set of Brembo discs (£400) after two track days due to overheating and cracking, I've run some extra cooling ducting through the front fog lamp vents.
A friend who runs a Seat Cupra in the Sportmaxx Cup, has poped out the fog lamps to install the ducting but I didnt want to loose them so cut in a section of pipe to connect the Forge 65mm V2 ducting.
Its a bit tight getting it through, had to relocate the Horns and get it over the Forge pipe work from the Intercooler but have managed to direct it onto the back of the brake discs, it's worked well on the last few trackdays.
Offline lswed30
Re: Brake Ducts
« Reply #3 on: November 20, 2008, 03:36:25 pm »
Good work!!
I notice that yours doesn't have the rectangle holes on the inner arch?
 Mine does, wonder why that is, I will get some pics later on. I've got to go to pick some parts up at VW later so will get the parts chap to have a look for me.
Re: Brake Ducts
« Reply #4 on: November 20, 2008, 09:02:49 pm »
I've got quite large rectangular holes in my front inner arches. It would be easy to duct to the brakes from my front splitter slots.
Offline billyboy
  • Billy lar
Re: Brake Ducts
« Reply #5 on: November 22, 2008, 05:57:23 pm »
Good work!!
like this
Offline lswed30
Re: Brake Ducts
« Reply #6 on: November 24, 2008, 04:49:00 pm »
yep thats the ones.
Thanks for not getting me to grovel around on the floor.
Was looking around t'other day and found a pic of an R32 with the brake ducts in so i'm pretty sure its the same. The only difference is the R32 had the edges of the arch radiiiiiiiied to help air flow presummably.
Be good if we could make use of them hey?
Offline keith
Re: Brake Ducts
« Reply #7 on: November 24, 2008, 08:47:15 pm »
That's what i have on my Ed, did wonder about them
On a dif note there was a mazda part a slated grill that was fitted to the inside arch that folks used to custom fit to their cars
Offline keith
Re: Brake Ducts
« Reply #8 on: November 24, 2008, 10:03:44 pm »
here's what i mean, 3rd pic down this guy has actually cut into his but you can buy a part and save the hassle.
