Finally snapped up an induction kit. 1 month old ITG with less that 400 miles. The bonus is it comes with the new cold air enclosed filter as well :) which is not going to be sold publicly via traders according to the chat I had with ITG.
I have both set up's so it gives a good chance to do some comparisons.
Visual DifferenceFirst thing is obviously the looks. The ITG maxogen seems a bit marmite and I can see why. For approx £350 the foam heat shields aren't what I would call a quality product. However the performance of this intake is well documented and I'm not entering any engine bay show and shine competitions any time soon so it wasn't something that put me off.
The original ITG intake (shown on an A3 2.0tfsi)
The "gen2" / "revised" / "enclosed" intake (as it has no official title I'm sure it will be called many things) Uses the same turbo connection hose, MAF housing pipe, expander hose, heat shield pipe and back 90 degree elbow hose as the original ITG intake. As I've said, ITG are not planning on releasing this kit as a package so you would need to have these parts from an existing ITG intake already.
The new parts are listed below (thanks to bigmig95):
ARAB65/84XL filter
STAB99 air filter housing
STAB99VWRCAISSPA slam panel adapter
Modified STAB99VAGTSIMB mounting bracket assembly
The revised / enclosed intake (again shown on a A3 2.0tfsi)
Looking closer at the actual filters. I removed the filter housing from the new filter (on the right) to show the difference
New style on the right. Old style on the left
CostAgain, because its not an official system there is no set cost as yet for the upgrade parts but its likely to be around £200 for extra parts.
FittingIf you already have an ITG fitted you can remove the filter, the front 90 degree elbow hose and the extension pipe that is screwed to the engine block. These are not used in the new kit.
First you need find the hose and valve shown here. Remove the hose clip and pull out the valve and shorten the hose by approx 10mm. then push the valve back in and re do up the hose clip
Then fit the new bracket. I used 7 of the supplied washers to lift it up to the correct height for the MK5 GTi
You may then want to add some protective wrapping or cut up some flexi conduit to protect the hose that the bracket ends up touching
Then fit the slam panel attachment in place and then slide the filter canister into the hose and then bring it forwards into the slam panel attachment (I have not yet got the correct slam panel part so no photos of this bit yet. This is just theory and I will amend this part once I have it fitted.
Aim to fit a good 30mm+ of the canister pipe into the rear hose
Then use the supplied strap over the canister pipe to hold it in place
Audible differenceDarth Vaders evil twin disappears with the new enclosed filter. You can still hear a slight whooshing on acceleration but to my ears is barely any louder than the stock intake and the whooshing and hissing on part throttle of the open filter is vastly reduced if not completely eradicated.
I will try to record engine bay and cabin audio in due course.
PerformanceSomething which needs much more testing and a rolling road but here are the results of some crude on the road logging sessions. remember this is without the slam panel adapter in place so the enclosed system was still probably sucking in hot engine bay air. Again this will be updated in due course.
I did 2 runs (1 in either direction) on the same stretch of road with each filter set up (so 4 runs in total). The runs were no more than 60 mins apart and the outside temperature was 19.5 - 20 degrees according to my dash. Run was done in 3rd gear on a DSG car
Incase the legend is too small to read.
Blue = open filter run 1
Red = open filter run 2
Green = closed filter run 1
Purple = closed filter run 2
Air mass
Temperature
XLS file from the open filter
http://u55158955@s300610021.websitehome.co.uk/UtilityImages/ITG%20open%20log.xlsXLS file from the closed filter
http://u55158955@s300610021.websitehome.co.uk/UtilityImages/ITG%20closed%20log.xlsThanks for looking.
This first post will be updated with new info as time goes on.
Nathan
