Author Topic: ITG maxogen - new enclosed filter information.  (Read 39879 times)
Offline jedi-knight83
  • -Receive: 41
Re: ITG maxogen - new enclosed filter information.
« Reply #75 on: July 13, 2012, 08:39:18 pm »
I feel I've opened a can of worms.
Perhaps I should ignore the maf / boost loggings and wait till the dyno to see what its really bringing to the table. TBH i cant feel much difference from the drivers seat on the road... but maybe my car isnt adapting itself to the intake well?
End of the day i dont mind selling and running stock.
My car made 234bhp on r-tech dyno which Nick felt was a little down so suggested removing the pre cat and getting an intake... both of which I have done. I only really want 240-250bhp but would like it nice and torquey and driveable so if we can get that with just the pre cat removed in the end then I'll be happy and if its ends up that the intake isnt adding anything on my stage 1 then I'll sell it.
I guess I was expecting it to be amazing and give a noticeable difference over OEM seeing as lots of people say what a good upgrade it is.
We will see what we can do next time your down.....  Remember last time you was running the turbo N75 duty flat out across the whole rpm range and only made 214bhp...  There are many factors to tuning,  3-5mm pre load on the actuator and a map tweak could get you closer to 255bhp as I found out the other day and that was on a stock filter.
Thanks Nick.
I think for now I should shut up  :ashamed: and go back to my stock intake and i'll bring all the bits with me on the 24th and see how we get on.
« Reply #76 on: July 13, 2012, 08:40:41 pm »
These kind of threads are for the good and benefit of all of us  :notworthy:
Nick what do you think of the forge actuator?
  • -Receive: 41
« Reply #77 on: July 13, 2012, 08:58:37 pm »
Thanks. tbh it has been the best part of an afternoon messing about swapping it over and logging... although im not sure how informative my logs are in reality?
Also.. you are right.. Till tonight I was still under the impression that an intake, whether it be forge or itg etc, was a top priority mod for any stage of remap even stock maps.
If it only adds less than 5 bhp and 5lbft for instance then for £300+ some may not consider it a worth while mod compared to the 10-15bhp that some people seem to claim.
Offline gigolo456
« Reply #78 on: July 13, 2012, 10:44:25 pm »
I have been led to believe that its a culmination of a remap, aftermarket air intake, and good exhaust system that any real gains will b seen, ie they all help each other to produce results! That said, I really feel that it was my TBE and remap that produce the biggest gains, with my Twintake being a nice 'optional extra'!
Offline badbwoy27
« Reply #79 on: July 14, 2012, 07:17:25 am »
Itg must have added quite abit more for me as when I first had a remap i only made 237 bhp on stage 1.then I had pre cat taken out and added itg intake and got back to Rtech for another power run and made 256 bhp. Now unless I gained 17 bhp just from pre cat the intake must have added a fair few horses. Oh and 256 bhp was made b4 any map tweaks.
h4rdy
« Reply #80 on: July 14, 2012, 07:33:25 am »
Can I add my Tupence?
I first fitted a BDM Intake (basically a ITG Maxogen copy). I took it off as I felt the car at 2+ was just tooooo mental. I also had a Decat Pipewerx DP to standard.
I then felt the urge again and bought a Forge Twintake which was sooooo loud and was not allowing my car to run right so again I took it off.
I then bought a used ITG Maxogen which I would say was the same as the BDM (obviously) maybe a little quieter.
When I had the BDM it MAFed at 330bhp which I would say is about right 9-5-9 settings. THS IC may be helping with that.
BUT.......the noise was unbearable. If it was a track car yes maybe ok.
I have enquired to VWR about the enclosed ITG and have been offered to go out in one of their cars which I am going to do as they are fairly local.
I now run the Pipercross Panel. I would say this is perfect for road use. In my opinion the car FEELS better not so 'blown' out?
I think the noise was affecting the outcome maybe?
The worst IMHO, ill repeat IMHO, was the Forge. Hated it. Car felt slower and the noise OMG!
I am looking forward to seeing/hearing the new ITG.
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #81 on: July 14, 2012, 10:13:26 am »
Combination of things , mapping and pre-cat removal, weather and time of year on the dyno.
What filter was you running prior to the ITG?
What I am saying is that we run a stock car with stock air box and filter then fitted £300+ induction kits and there would be very little or no peak power gains.  Same with stage 1 TFSi setups
 run the car back to back with the stock filter and an £300 induction kit we will only ever see 4-5bhp at points is the midrange but nothing really on the peak numbers. We see the same results at stage1 with a £35  pipercrosss filter.    If the air is cooler then the engine is going to be more efficient and help keep the peak numbers consistent
Now when going to stage2 and above to the point where the stock air box is limiting the peak air flow and the turbo is at the high end of the VE band at high rpms, then with the induction kits we start to see nice peak power gains on dyno graph and via the air flow logs.
The effect people can feel is the turbo spooling faster down low and moving the torque band and a few hp added to the avg power number
Dont expecting big peak bhp number from any induction kits..  if your expecting to take a stage1 car from 240bhp to 255bhp peak just from filter, it just aint never going to happen.
If anyone or company wants to test an induction kit on our dyno and via logging I am more than willing to provide the dyno time for free.
Copy and paste from Golf gti forum
This is when we tested a kit for Pipercross and they expected to see 14bhp+ gains stock and at stage 1.
Ever the pessimist, I wasn't going to believe it until I saw it and today I had the chance to do just that!
http://www.pipercross.net/fastroad/products_venom.asp
Ignore the red pipe, the kit we tried today was all tasteful black and by far the most OEM looking off-the-shelf CAI i've ever seen. It also took less than 10 minutes to fit. They've made a special effort to make it match the existing finish of the plastics in the mk4 bay.
The victim was a 2001 1.8T GTI (AUM) - Ben's old motor, so we knew it was a 'good un' and was put back to standard when he sold it other than a remap and DV, so we could get a fair test on a standard motor rather than use my loony 1.8t
We did a session of 3 dyno runs and a held load test with the car in 4 different states of tune. After each session the engine was allowed to cool until the inlet manifold was cold to the touch, IAT reported 21 degrees at idle and the coolant was at 40 degrees then warmed to 84 degrees at the start each batch of testing. The man from Pipercross looked upset when the numbers came up on the rolling road computer, his face was priceless. But I'd been watching the data and knew there was a lot more to the story, and anyone who has been to the R-Tech workshop has probably had the lecture on average horsepower vs. peak horsepower. However here are the peak figures for you to chuckle at!
Stock filter/airbox and stock mapping.  - 160 bhp
Stock filter/airbox and Spec 1 mapping.- 210 bhp
Pipercross venom and stock mapping.   - 161 bhp
Pipercross venom and Spec 1 mapping. - 210 bhp
Looks pretty pointless, no? To be honest it's what I was expecting, especially with an engine/ecu that i know so well. Our VW's are too well designed to be tricked into making more peak power with air filters, the ecu knows all the time exactly how much load is being worked and will compensate within it's efficiency to always hit the same numbers. Peak numbers are pub talk, how you get there.. the average figure, is what makes a quick car. Average bhp between 2200rpm and 6800rpm was increased by about 5bhp with the CAI, whether remapped or not, and that's a lot for a simple bolt on air filter.
While Nick was showing the slightly-happier-by-this-point Pipercross dude how the average bhp is calculated by the sportdyno software I went away to find in the logs what was going on to cause this change. It didn't take long to see what was going on once the intake air temperature and measured air mass graphs were overlaid. With the Pipercross kit installed, the intake temperatures reached were decreased by as much as 9°C compared to the stock airbox on power runs and as much as 15°C under held load. That's maximum stress, the equivalent of towing a caravan up a steep hill at 5500rpm in 4th gear. Ambient air temps were between 5 - 8 °C all day thanks to the blizzard. The more efficient burn (particularly in low revs) was allowing a bit more punch between 2000 - 3500 rpm thanks to the ecu adapting timing which gave the boost in average bhp, and as an added bonus (ME7.5 ecu's only for this next part.. sorry AGU boys ) once approaching peak the fuel injection was being altered to suit and fuel consumption was noticeably decreased at high revs!
01455 617233
« Reply #82 on: July 14, 2012, 10:24:38 am »
....True if only adding a high-flow tubular induction kit. But it's a different story when combined with a Stage 2 remap and a TBE high-flow performance exhaust. < Perhaps this is what you are saying.
http://www.mk5golfgti.co.uk/forum/index.php/topic,9988.0.html
  • -Receive: 41
« Reply #83 on: July 14, 2012, 10:51:07 am »
You say it makes the turbo spool earlier. Well on a couple of runs I did the boost actually came in later than with the stock air box?
This backs up what I've seen in a couple of posts now where people say the itg felt a bit laggy at the low end.
All this also goes directly against red robins findings when he fitted his twintake and he is only stage 1?
Im very confused now.  :confused: <<< see... thats my confused face!
All I can say for certain is that at present the itg doesnt 'feel' much quicker on my car (although ive been chopping and changing so much and resetting the ecu that maybe it needs to settle again), it makes a horrible noise that IMO is not acceptable for an intake, and the mpg has dropped 5-7mpg on average runs where I'm not pushing very hard.
My own logging has shown a small increase in airflow g/s across the rev range, between 4-10g/s although the itg g/s was very up and down compared to the smooth increasing line of the stock box. Also the boost seemed to dip in the low revs (below 2500rpm) with the itg compared to stock but then it seemed to hold boost longer in the higher revs.
All of the power increases (or lack of) are pointless though if I / ITG cant stop the whistle and if thats just a side effect of any intake then I'll stay stock
Offline Janner_Sy
  • -Receive: 113
« Reply #84 on: July 14, 2012, 11:54:58 am »
I had an ITG on my Octavia vRS at stage 1 and the difference was very very noticable.  Might be worth RTEc doing a full health check on your car because something doesnt sound right.
What a few of the guys said about the big gains being noticeable at higher stages of tune is correct as well.  The stock airbox has a limit which is much lower than the uprated intakes so gains get bigger the higher the stage of tune or more aggressive the tune.
Robin was REVO stage 2 BTW with full Miltek TBE when he fitted the twintake.  Also bear in mind that it wasnt just a direct fit.  JKM also altered his REVO settings to accommodate the intake to its best capability.
Id say the figures below are the norm on an accurate rolling road
Stage 1 235-240hp
stage 1 with intake 240-245hp
stage 2 with TBE + stock intake 245-255hp
stage 2 with TBE + intake 255-265Hp
Stage 2+ with TBE, HPFP + stock intake 260-270Hp
Stage 2+ with TBE, HPFP + intake 275-285Hp.
Its all dependant on how aggressive or mild your map is as well.  If your map isnt pushing the car much, the intake might not produce the same amount of results/gains.
« Reply #85 on: July 14, 2012, 01:52:06 pm »
....No, as Sy says, I was at Revo Stage 2 when my Twintake was fitted (and I already had the Milltek TBE for years while both standard and Revo Stage 1).
And also as Sy says, JKM altered my Revo settings to accommodate the intake and to stop the likelihood of my OEM fuel pump struggling and consequently creating lag and/or fuel cuts. Now I have an APR pump, JKM has upped my Revo 2 settings. It's all in the Twintake review thread I wrote.
Anyway, that's perhaps not directly related to this thread about the enclosed filter ITG Maxogen.
  • -Receive: 41
« Reply #86 on: July 16, 2012, 11:01:42 am »
not sure if i should post here or start ANOTHER itg thread  :sad1:
Still not loving the ITG. MPG still terrible. Drove over to a friends last night and made sure i drove really carefully. Its about 15 miles, bit of A road and dual carriage way. I just cruised over at about 60-75mph all the way. 25mpg again.
So far ive used over 3/4 of a tank and only got 185 miles.
After my first R-Tech visit but BEFORE the ITG I was getting 30+ on a run and got 340 miles to a tank (more than I've ever had with this car) and the car felt awesome and I was pushing it a lot.
So something is not adapting correctly with the ITG surely?
Tempted to just remove it and sell now... but would like to get the the bottom of certain noises and see if it really can help performance on a stage 1 when I revisit R-Tech next week.
h4rdy
« Reply #87 on: July 16, 2012, 11:09:59 am »
Do you know what your map is requesting from the fuel pump?
  • -Receive: 41
« Reply #88 on: July 16, 2012, 11:13:11 am »
not sure. Which vagcom block would it be. Maybe i logged it the other day.. if not i could pop out and log it today
h4rdy
« Reply #89 on: July 16, 2012, 11:28:43 am »
The only time my fuel economy went down was when I went 2+.
